Upgrading from 17" OEM Wheels to 18" OEM wheels
I have a 2002 Maxima and and am trading in the 17" wheels for some 18" wheels. After searching, I believe that I want a 40 profile tire, correct?
I want to make sure that the diameter of the new wheel package is no larger than othe old (i.e. don't want rubbing, or speedo problems).
Long story short, 45 profile will not work, am I right???
Thanks Guys.
Thanks Guys.
45 will work...but its supreme bubble gum bubble yum status. 40series IMO is perfect. i ran 245/40/18s when i had my G35 wheels on and loved it...went to 235/40/18...long story short, i traded them wheel/tire for another set of wheels and tires as i wasnt liking how it looked
245/40/18
245/40/18
245/40/18
245/40/18
What looks better on OEM Infiniti wheels, 40 or 45 profile?
What matches the oem diamater on a 18", 40 or 45 profile?
i dont know if you can see in this pic too well..but thats 245/45/18 tire that was on the G wheels when i first got them
i quickly got rid of them for the 245/40/18 tire....'bubble gum' status is just a term for a high profile tire opposed to a lower profile...my personal terminology.
if i'm correct, i beleive 245/40 corresponds to the factory spec as far as overall diameter to the 17" oem wheel/tire combo
1010tires.com has a good tire calculator that you can compare stock size to any plus size. All you have to do is punch in the sizes you want to compare and it will give you all the info you need. If you are looking for speedo accuracy, a 245/40/18 would be the closest match. Check it out!!
http://www.1010tires.com/tiresizecalculator.asp
Yeah I dont think they always be right cause on a 8.5 they said roll with a 225/45 when everybody else would get the 245/40 I seen a guy on 20's but he had the 235 instead of the 245 and his rim was just out like WTF even a guy at a shop says get the tires width that is flush with the wheels or you will have problems down the road!!
aminus21
09-12-2015 04:53 PM
