Go Back   Maxima Forums > Maintenance, Tech, & Care > Tires and Wheels
Sponsored by:
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 11-01-2009, 08:20 AM   #1
Offset/size calculator question
Running through different scenarios on the Rims-N-Tires calculator, I notice for wheel wells it says "will fill out wheel well extra ...."
What do they mean by "fill out" ? Does that have anything to do with how far the wheel comes out towards the fender? (i.e. more flush with the body)....or is more of a distance between the outer diameter of the tire vs the wheel well lip?
Just trying to determine what wheel/tire combos wont rub on my car......should I be looking at the "fender" section of the calculator? Ive always called up front fenders, but in the back "wheelwells" so I might be a little confused.
Thanks in advance.
-Chris
chrisexv6 is online now   Reply With Quote
Old 11-04-2009, 09:12 PM   #2
Offset Is Everything.
Send a message via AIM to MrDicks95SE
the wheel well is the entire "tub" or "well" the wheel sits in whether it be front or back. do the calculations using the wheel/tire calculator from the miata site in the stickied links. measure and figure it out. this has been discussed NUMEROUS times over and over again. tire sizes are also discussed as well.
other questions you need answered are:
are you lowered? how low? tire size? wheel size? wheel specs (ie offset and width)? cambering? etc. please use the SEARCH functions as it is readily available. dont be lazy.
MrDicks95SE is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
