Go Back   Maxima Forums > Maintenance, Tech, & Care > Tires and Wheels
Sponsored by:
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-29-2009, 11:16 PM   #1
Will They??
I've searched, measured and looked at charts but I still want expert opinion or someone that has done it. I would also appreciate some pictures of cars with wheels and tires of the specs I mentioned for 6Gen Maxima.
Im not new to custom world but I am to Nissan Maxima. I have a 2006 SE and I really like the wheels off the new 370Z. They are 19s made by Rays Engineering. The specs are:
19x9 front with 40mm offset
245/40/19
19x10 rear with 30mm offset
275/35/19
According to everything I read, charts I looked at and measurements I took, these will stick out too much but I don't want to give up on the idea just yet until my suspicions are confirmed. Thanks for any insight and help.
__________________
RAZ76 is offline   Reply With Quote
Old 10-30-2009, 08:58 AM   #2
My axles cry for mercy...
essential1's Avatar
They should fit. If they dont.... make them fit.
At the most, all you might have to do is run a smaller tire. 6th gen fenders are "roled" from the factory if i'm not mistaken so you wont really have to worry about modding the fender too much. Unless you wanna pull them a little.
What suspension are you on by the way.
__________________
01 I30, [5 speed swap][4th gen pedals and master cylinder][OEM clutch][OEM flywheel][ksport coilovers front, D2 coilovers rear][10k hid headlights and fogs][custom WAI][cattman exhaust][tenzo type-M, 19x8.5 +17F, 19x10 +22R][300zx calipers][Cobra 13" drilled and slotted rotors]
5 speed swap myths BUSTED:
1. Both driver and passenger side AUTO axles work fine.
2. AUTO flywheel bolts work fine.
essential1 is offline   Reply With Quote
Old 10-30-2009, 09:50 AM   #3
Right now stock but I think I might go with a mild drop from Progressive with Bilstein struts/shocks.
You don't think they will stick out past the fenders??? That's my concern, since they are so close to being flush right now. Acording to the charts I looked at it shows this:
Current Wheel Specs- 18x7.5" Offset 40mm
New Wheel specs 19x9 front and 19x10 rear
These measurements are compared to current setup. Got the info from http://www.1010tires.com/WheelOffsetCalculator.asp
For the rear: Inner Clearance: 22mm Less
Outer Position: Extend an extra 42mm
For the front: Inner Clearance: 26mm Less
Outer Position: Extend an extra 12mm
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
