Go Back   Maxima Forums > Maintenance, Tech, & Care > Tires and Wheels
Sponsored by:
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-08-2009, 03:56 AM   #1
Send a message via AIM to MIK3
.6 lbs or .5" for track wheels?
Looking for track wheels later down the road and am pretty convinced I'll be doing two 17" Enkei RPF1's up front. My two options:
17x9 @ 15.9lbs
or
17x9.5 @ 16.5 lbs
Which set up would be more advantageous? I'm not sure how a reduction in 1.2 lbs would compare to 1 more inch of tire on the track. Thanks in advance.
__________________
MIK3 is offline   Reply With Quote
Old 10-08-2009, 12:56 PM   #2
STFU n00b!
go for more tire.
__________________
04 G35 Sedan 6MT- The DD
96 240SX 5 speed- The track toy
93 Maxima SE 5 speed- retired 1-5-09
Check out the toys I make on my website!
Matt93SE is offline   Reply With Quote
Old 10-10-2009, 09:54 PM   #3
Offset Is Everything.
Send a message via AIM to MrDicks95SE
go with the 17x9.5 and run more rubber.
MrDicks95SE is offline   Reply With Quote
Old 10-12-2009, 04:27 AM   #4
So I have two for more tire. I was feeling this way as well. Am starting to wonder if there will be an issue with fittment...
__________________
Old 10-12-2009, 06:14 AM   #5
Crusher103's Avatar
Send a message via AIM to Crusher103
tires are going to weigh between 20-25lbs anyway so just go for the wider wheels, .6lbs is not going to make a difference.
__________________
96 Black I30t VLSD 5spd A.K.A Big Black(has a bad attitude)
Eibach springs//Koni yellows//Koyo OE Radiator//F&RSTB//Black retro'd Cefiros w/E46 Bi-Xenon projectors/ZKW clear lense'd//Budget y-pipe//test pipe//Apexi WS2//WAI//Grounding kit
3.5 in progress
CLICK ME FOR WHEELS FOR SALE AND TIRES FOR CHEAP
Crusher103 is offline   Reply With Quote
Old 10-12-2009, 11:44 PM   #6
offsets man, list the offset.
Old 10-13-2009, 12:06 AM   #7
17x9.5 +35-38 is PERFECT with 2 degrees of camber in the front. Roll fenders to fit.
__________________
1998 A32
JIC FLT-TAR, O.Z. Pegasus 17x9 ET+24, 95-96 Front End Conversion
Fast1one is offline   Reply With Quote
Old 10-13-2009, 01:17 AM   #8
Quote:
Ah, sorry about this.
17x9 = 38
17x9.5 = 35
I believe these are the only offsets available for these specific sizes.
__________________
Old 10-13-2009, 08:25 AM   #9
Quote:
17x9 = 38
17x9.5 = 35
Do it, the latter will fit perfect for wide rubber.
By the way, those are NOT the only offsets for those sizes unless they have been discontinued. Pretty sure they were special order, but you can get pretty low...
__________________
1998 A32
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
