Go Back   Maxima Forums > Maintenance, Tech, & Care > Tires and Wheels
Sponsored by:
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 09-17-2009, 01:20 PM   #1
Send a message via AIM to tyler5619 Send a message via Yahoo to tyler5619
tsx wheels on a (4th gen) max
I have searched my a.ss off and have decided to just make a damn thread already.
My question is this:
Will this 2004 Acura TSX wheel fit on my 1997 Maxima WITH NO MODIFICATION? Or, if modification is needed, how much? I'm concerned about the center bore. Every search result says they will, but do not say why. From what I can gather, the Max center bore is 66.1 while the TSX is 64.1. A single millimeter on either side doesn't sound like much, but you never know. Thanks much.
__________________
SHIFT_no bailout.
A32. QN0. 5MT. FTW.
Current mods.
JVC HU. | 35% tint. | Blackout center caps. | Indy fogs. | Blackout Maxima badge. | Custom blackout SE badge. | Clear bumper lights. | A33 OEM clutch. | HTP MAF adapter, AMSoil cone filter. | NGK Iridium spark plugs. | eBay FSTB. | WarpSpeed y-pipe. | White & bright clock. | Custom 2.5" b-pipe. | Custom G20 sidemarkers. | E46 Bi-X, 6K D2S. | Thrush glasspack. | Magnaflow muffler. | Full tank of 93 octane.
BIRD COUNT: 2.
tyler5619 is offline   Reply With Quote
Old 09-17-2009, 01:43 PM   #2
rims
it should fit right in . my buddy has tls and is the same lug pattern. let me see pics if u put em on
96MAXIGLE is offline   Reply With Quote
Old 09-17-2009, 01:48 PM   #3
I'm needing a caw
Jeff92se's Avatar
If that hub bore is correct, it will not fit. The hub bore specs are fairly tight so the wheel is centered and does't create vibrations
__________________
2003 G35 Sedan. Mods comin'
3-gen parts for sale
Sold Jan 14, 2006'
Mod list:
Eibach/Konis - ST front sway bar/Addco rear bar - Blemco rstb - Otto fstb
350Z 18" touring wheels.
Modified Cattman Y, Custom flex, 4-gen Carsound cat, Custom cat-back, Y2K muffler
Custom CAI, custom ground kit, JWT ecu, Fidanza flywheel, ACT clutch, Jeff92se Cobra 13" bbk with 300zx 30mm polished alum calipers.
Jeff92se is offline   Reply With Quote
Old 09-17-2009, 01:57 PM   #4
^^ i don't know for sure, i was hoping someone on here would have a more reliable source. is there a such thing as removing the existing hub ring and replacing it with my hubcentric rings? i have a set of 66.1 rings...
__________________
SHIFT_no bailout.
A32. QN0. 5MT. FTW.
Current mods.
BIRD COUNT: 2.
Old 09-17-2009, 01:59 PM   #5
I'm needing a caw
Jeff92se's Avatar
oem wheels don't have hub rings.
__________________
Sold Jan 14, 2006'
Mod list:
Old 09-17-2009, 02:05 PM   #6
^^ i was afraid of that.
__________________
SHIFT_no bailout.
A32. QN0. 5MT. FTW.
Current mods.
BIRD COUNT: 2.
Old 09-17-2009, 08:14 PM   #7
You may be able to get it bored out, or a custom spacer made (people will recommend against this) but otherwise no, it won't fit with a 2mm smaller center bore.
MorpheusZero is offline   Reply With Quote
Old 09-18-2009, 12:31 PM   #8
Quote:
did your buddy have to modify those TL's?
__________________
SHIFT_no bailout.
A32. QN0. 5MT. FTW.
Current mods.
BIRD COUNT: 2.
Old 09-18-2009, 03:26 PM   #9
Saw a 4th gen member here with TL wheels and I messaged him to see if he did anything to fit them. Turned out he had to machine the bore size a little bit.
__________________
IHATEMY2KMAXIMA
IHAVEA2KMAXIMA is offline   Reply With Quote
Old 09-19-2009, 05:10 PM   #10
Quote:
this. i tried rsx wheels and it didnt fit. our hub bores are larger than honda/acura ones.
__________________
|VQ35DE w/3.0 timing Components|Vortech V2 SC w/ 3.33" pulley|440cc Injectors|AEM Methanol Injection|y-pipe|3inch exhaust|KSport Damper|Stillen Lip Kit|Carbon Fiber Hood|Work Equiped
emdot is offline   Reply With Quote
Old 09-19-2009, 07:06 PM   #11
thanks everyone for saving me $250!
__________________
SHIFT_no bailout.
A32. QN0. 5MT. FTW.
Current mods.
BIRD COUNT: 2.
Old 10-07-2009, 03:52 AM   #12
it wont fit
streamway0 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
