Hub bore help. BBS RK on 5.5 gen
I bought a set of used BBS RK wheels from a local guy on craiglist and to my surprise the hub bore was slightly smaller the the OEM bore on my Maxima. The wheels are 18x7.5 and were on a Toyota Camry. My question now is, can I take these wheels to a machine shop and have them mill the amount of material off these wheels or is that a no no? The fitment is so close (I can actually get the wheels on the first few threads of the studs) and the wheels have somewhat of a bump in the bore that would likely fit if they were milled. I really hope these will fit I really like the wheels and they are light. Any advice is helpful.
__________________
2002 SE 6-speed HLSD: WM STS, ES poly shifter bushings, PR CAI w/ K&N, SSIM, Hotshot headers, Warpspeed MS cat, Cattman Cat-back, ES Motor Mounts, TS L-Spec, Emanage Blue, Cleared out turn signals, Black headlight housing, Umnitza DDEs, Progress RSB, Powerslots/Hawk HPS, Fidanza aluminum flywheel, Exedy Stage 1 clutch, 06 G35 Sedan seats.
