Go Back   Maxima Forums > Maintenance, Tech, & Care > Tires and Wheels
Sponsored by:
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 09-09-2009, 11:22 AM   #1
Fix-a-Flat in a tire PLEASE HELP!!!
Im pretty sure I have a slow leak in my tire somewhere. I have to put some air in it about once a week so its not a huge leak. I was thinking if I put fix-a-flat in the tire it would stop the leak. Or is fix-a-flat just a temporary fix to get to the tire shop? I also have chrome wheels and don't know if the fix-a-flat will corrode the chrome on the inside of the wheels. Is this bad to do? Are there any suggestions for an alternative to fixing this problem (without the obvious of buying a new tire)?? Thanks in advance
wickedmax13 is offline   Reply With Quote
Old 09-09-2009, 03:21 PM   #2
Anyone have any input at all??
Old 09-09-2009, 03:30 PM   #3
Haha we did this for a tractor, but simply, its a temporary fix. You will have to keep on using fix-a-flt once in a while in order to keep the tire "sealed"
My brother has a tractor that he punched a hole in by running over a nail and instead of getting the one HUGE tire replaced for a HUGE price, he just used fix a flat and it seems to seal it up nicely! Except he has to keep doing it like once every couple months.
__________________
1997 Nissan Maxima GLE
Leo_Koneval is offline   Reply With Quote
Old 09-09-2009, 03:46 PM   #4
Go get new tire. The fix-a-flat is only a temporary fix so you wont get stranded.
__________________
IHATEMY2KMAXIMA
IHAVEA2KMAXIMA is offline   Reply With Quote
Old 09-10-2009, 06:17 AM   #5
kgallerie's Avatar
If leaks that slowly, it may be in the seal with the rim. You may want to try to have it re-seated. Clean the contact surface really well between the rim and tire when the tire is off.
kgallerie is offline   Reply With Quote
Old 09-10-2009, 12:29 PM   #6
SLOW
Nealoc187's Avatar
Send a message via AIM to Nealoc187
take it and see if they can patch it
__________________
95 SE - Stock 3.0L w/ USIM - T61/P-trim @ 14.5psi - 93 octane
11.76 @ 121 - 1.82 60' - ET Street DOTs
12.15 @ 123 - 1.95 60' - Nitto DR
3.5L swap with I/Y/E
12.92 @ 104 - 1.69 60' - M&H Slicks
13.60 @ 103 - 2.15 60' - Street tires
96 GXE - I/Y/E/MEVI/JWT ECU
13.42 @ 102 - 1.87 60' - M&H Slicks
13.82 @ 102 - 2.17 60' - Street tires
95 GXE - Stock winter beater
14.28 @ 95 - 2.07 60' - Street tires
High Flow Fuel Injectors
Injector Cleaning & Servicing
www.DeatschWerks.com
Nealoc187 is offline   Reply With Quote
Old 09-10-2009, 12:31 PM   #7
Take it to get looked at a patch shouldnt be that much at all...
I put fix a flat in an Accord i had, because of a slow leak and it fixed it.
Was a beater so i didnt see it worth buying a tire for it.
* I wish SLIME worked for cars.
__________________
" The pursuit of happiness, one horsepower at a time "
RacerX1320 is offline   Reply With Quote
Old 09-10-2009, 06:28 PM   #8
Took it to the shop and had em rebead it. When it was originally mounted from the manufacturer I bought them from, their machine took a small sliver out (not enough to effect performance) of the tire where it needs to seal to the rim and the sliver was folded and stuck in between the rim and tire causing a tiny tiny opening where air could only leak from when the wheels are on the car due to the weight of the car. Easy fix cost me $10....thread squashed. Thanks to all who commented.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
