Size needed
Old 03-24-2009, 11:16 AM
Bassbreaker's Avatar
Size needed
Ok...I bought a set of wheels from another org member but there wasn't any info given aside for the fact he said they were a direct max replacement. I have a 95 GLE and he had a 96. They are 17" Enkei wheels. I'm not to up on offsets or anything because i've never came across the need to look. I'm at work now and i don't have the rim in front of me but I need to know what size tires to get when i leave here.
If they are a direct maxima replacement then is there no offset? I can get a good deal on a set of 225-50-17's if they will fit.
On tirerack.com they only give 235-40-17 as the tire replacement.
Would I have a problem with the 225's? Or would I be better off going with the 235's?
Thanks alot guys
Bassbreaker is offline
Old 03-24-2009, 03:21 PM
IHAVEA2KMAXIMA's Avatar
225/235 both should be fine.
IHAVEA2KMAXIMA is offline
Old 03-24-2009, 05:51 PM
Ok, I think i'm going to go with the 235/45 r17's
That should look nice
Old 03-24-2009, 06:16 PM
Former Vendor
BLACKonBLACK98's Avatar
how do you get a recommendation for tire width without listing rim width?
doesn't sound like you're ready to buy to me. report back with more info or take a chance.
BLACKonBLACK98 is offline
Old 03-24-2009, 07:01 PM
MorpheusZero's Avatar
Stretch some 185s on it. It'll look mad stylin'.
MorpheusZero is offline
Old 03-24-2009, 07:25 PM
Former Vendor
only if it's a 10.5.
Old 03-24-2009, 08:38 PM
Offset Is Everything.
MrDicks95SE's Avatar
i second that motion.
MrDicks95SE is offline
Old 03-25-2009, 04:15 AM
i looked when i got home and they are 17 x 7
no offset stated on them.
So, should 235/45 17's work?
Old 03-25-2009, 06:59 AM
Former Vendor
235 will be a fatty bubble tire. if that's what you want then go for it. personally i'd go 205-215.
Old 03-25-2009, 07:10 AM
in the very top picture there is 235/45 r 17's. Do you think they look fat and bubbly? I would have thought that 205 would be to narrow for the rim...but i don't know much about it. If you say that 205 - 215 would fit fine, then I may go with those cause there is a significant price difference in 235 and 205...so maybe a 215/45(or 50) r17 would look good. I do like the look of a wide tire though but I don't want my spedometer to be off either.
The 235/45 r17 is what tirerack recommends for the 4th gen
Old 03-25-2009, 07:39 AM
Former Vendor
that tire must run narrow cause that's fairly squared off for a 235 on a 7. actual width will vary from manufacturer to manufacturer. tire rack's system is garbage. love the company, hate the site.
there's a lot of preference involved so it kind of depends on what you are looking for, however i plugged in some numbers and found a 215/50 to be a nice match for width (by my standards... on the tame side) and an outstanding od match.
disclaimer: i run 235 on 9-9.5, 215 on 8-8.5 so my recommendations are going to be towards the undersized because that's what i prefer.
215/50-17 is a safe bet though i would say.
Old 03-25-2009, 07:58 AM
perfect man...You probably just saved me alot of money and hassle.I appreciate it. You clearly know alot more about this than I do, so I will take your advice.
Cheers
Old 03-25-2009, 08:12 PM
Doctor D I presume???
doc2278's Avatar
very BAD idea thats asking for trouble right there LMAO.
doc2278 is offline
Old 03-26-2009, 04:06 AM
lol...yea, i don't think I was planning on putting tires on which are smaller than stock on an aftermarket wheel
smplyamzng
12-13-2015 01:19 PM
MichMaxFan
Garage and Workshop
09-02-2015 06:35 AM
maximaham
08-20-2015 10:23 AM
TonyJr
08-20-2015 12:14 AM
Max8
08-15-2015 07:06 AM
Quick Reply: Size needed
