Can 225/50/17 tires go on 235 rims?
Old 01-04-2009, 09:23 AM
blackmax42's Avatar
Looking to buy a guys 225/50/17 tires, but discovered that the AE 5th gen 2001 max rims are 235(50/17).
My understanding is that 225 tires will be 10 mm too small for the rims?
Anyone know if this is this safe/ acceptable or just a mismatch.
Thanks!
blackmax42 is offline
Old 01-04-2009, 09:46 AM
Former Vendor
BLACKonBLACK98's Avatar
first of all it's a 7" rim (iirc) not a 235, and yes you can i f you want. speedo might be a bit a little off and you'll have less contact area but you can do it. no problem. i've got a 215 on an 8.5.
BLACKonBLACK98 is offline
Old 01-04-2009, 10:13 AM
allblackmax96's Avatar
my buddy has 225/50r17 on his ae with no problems, i beleive they came with that size....
allblackmax96 is offline
Old 01-04-2009, 10:19 AM
Should be fine.
ChrisMan287 is offline
Old 01-04-2009, 11:28 AM
jasonmax's Avatar
225's on 7' rims are perfect.
jasonmax is offline
Old 01-04-2009, 11:16 PM
96blkonblkse's Avatar
Stock SE/GLE rims are 17x7. Ideally 225 is as wide as you will want to go on a 7", but you can run a 235. The handling will not be as precise as a 225, but it will work.
Hell if you think a 235 on a 7" is bad, a guy came into my work with his 03 G35 Aero with 255/40/17's on the stock rims..and they are 17x7 (5 spoke aero wheels).
96blkonblkse is offline
Old 01-07-2009, 05:16 PM
thomatt12's Avatar
It's a perfect fit and will look good too on a 7" rims.
__________________
do it yourself car repair
thomatt12 is offline
coolsun
Wheels/Tires
11-13-2016 05:01 PM
Fbana41
08-29-2016 12:18 PM
Garrettz459
09-28-2015 02:50 PM
Quick Reply: Can 225/50/17 tires go on 235 rims?
