Go Back   Maxima Forums > Maintenance, Tech, & Care > Tires and Wheels
Thread Tools Display Modes
Old 08-28-2008, 12:52 PM   #1
Mauja He Mauja
ZIPPIN's Avatar
Excessive wear on onside
I have the 350z wheels. Slight negative camber in the rear wheels. Today I noticed the insides of both rears are wearing excessively. Front only H&R drop. Rear suspension is stock.
Any ideas to fix that?
__________________
ZIPPIN is offline   Reply With Quote
Old 08-28-2008, 02:58 PM   #2
Send a message via AIM to MrDicks95SE
slight positive camber in the rear? are you sure?
easiest solution if asymmetrical: rotation. switch passenger to driver and vice versa.
__________________
MrDicks95SE is offline   Reply With Quote
Old 08-28-2008, 04:25 PM   #3
I think you mean negative camber /--\ . wearing on the inside from negative camber is going to happen when you are lowered unless you have adjustable camber plates to bring it back to spec. Even then, Im not sure if anyone makes adjustable camber for the rears so the only thing is to rotate your tires or have the shop take the tires off and mount the worn side to the outside.
Nismo is offline   Reply With Quote
Old 08-28-2008, 05:03 PM   #4
Are you lowered.? If yes try some camber.
__________________
*Cheap T-mobile Phone
http://forums.maxima.org/other-sale-...-t-mobile.html
Nov-2008
*2002 SE 45K Springs
http://forums.maxima.org/5th-generat...ml#post6626906
Nov-2008
Snypa is offline   Reply With Quote
Old 08-28-2008, 05:10 PM   #5
I dont think you can set camber for the rear since it's a solid beam.
IHAVEA2KMAXIMA is online now   Reply With Quote
Old 08-28-2008, 08:44 PM   #6
Mauja He Mauja
ZIPPIN's Avatar
Quote:
I was incorrect about the camber. You are correct. It is negative camber. I'm only lowered in the front with H&R's. Rears are stock. I have rotated them and still noticed the camber. Of course I can only rotate, side to side. Wheels are staggered.
__________________
Old 08-28-2008, 08:47 PM   #7
Mauja He Mauja
ZIPPIN's Avatar
Corrected. It is negative camber.
__________________
Old 08-28-2008, 09:54 PM   #8
Beam is solid in the rear, so if your alignment is off then either:
-your beam is bent. get someone to bend/box it back or get a new beam.
-your rear wheel bearings are so worn out that there is a 1+ degree runout.
__________________
All stock.
MorpheusZero is online now   Reply With Quote
Old 08-29-2008, 02:03 AM   #9
+1 no negative camber in rear is possible unless something is really off.
__________________
Old 08-29-2008, 05:22 AM   #10
Mauja He Mauja
ZIPPIN's Avatar
Thanks guys. Where can I get the beam checked out?
Old 08-29-2008, 08:38 AM   #11
I have about 1.5 degrees of - camber in the rear
__________________
All stock.
Old 08-30-2008, 11:12 AM   #12
ive got some toe-in on my rears.
__________________
Old 08-30-2008, 09:18 PM   #13
Newbie-Just Blazed
Send a message via AIM to QNO_A32
go and get an alignment, the sensors will let you see if the rear beam is bent. that thing should be dead on, mine even is with stech/illumina.
__________________
SHIFT_ A REBUILT TRANNY
QNO_A32 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
