Go Back   Maxima Forums > Maintenance, Tech, & Care > Tires and Wheels
Thread Tools Display Modes
Old 08-01-2008, 04:37 PM   #1
350Z 6-Spoke Alloy front offset, lowering gonna be ok??
I have the 18" 6 spoke 350Z wheels (OEM) with OE bridgestone potenza's.
The front sticks out of the fender well a little bit, what I'm wondering is whether this is going to affect lowering which I'll be doing soon hopefully. I am slightly worried about clearances and am hoping that some of you have dealt with this and can let me know. If there is going to be an issue I suppose I'll have to get them machined.
BTW I am lowering about 1.5"-2"
Thanks, hoping for some solid answers on this.
Matt
__________________
______________
<<'87 Z31 VG30ET (FOR SALE) <> '97 A32 VQ30DE>>
TunerMaxima3000 is offline   Reply With Quote
Old 08-02-2008, 08:03 AM   #2
It should be around +30 for those wheels.
__________________
OEM RIMS FTW!
WhiteA32 is online now   Reply With Quote
Old 08-03-2008, 01:41 AM   #3
Send a message via AIM to MrDicks95SE
the 350z setup would be a small staggered sizing. put the wider 8.5 in the rears. what tire size are you running? If its the 350z size, the sidewalls gonna be one size too tall. get the right size tire and you will be fine. ( 45 ---> 40.)
__________________
MrDicks95SE is online now   Reply With Quote
Old 08-03-2008, 12:40 PM   #4
the 6spoke z wheels are 18x8 +30 all around. only staggering is the tire size.
nothing a little stretch & camber cant fix right?
IHAVEA2KMAXIMA is offline   Reply With Quote
Old 08-03-2008, 01:10 PM   #5
Sorry I forgot to post tire sizes.
They are stock tire sizes,
FRONT - 225/45/R18
REAR - 245/45/R18
So I'm confused, are you saying that the wheels themselves are the same? Same offset width just with wider tires on the rear?
The tires are new, I'm not going to be changing them. So how low can I go? There seems to be a good bit of clearance to drop 1.5"-2" but as I said, I want to be sure before I get struts/springs.
Thanks guys!
Matt
__________________
______________
Old 08-03-2008, 01:14 PM   #6
FRONT - 225/45/R18
REAR - 245/45/R18
Thanks guys!
Matt
Yep that's exactly what I'm saying if I remember correctly. All four wheels have identical spec except different tire size from factory.
I dont know much about 4th gen, but I would guess that you will need to shave or roll your fenders.
Old 08-03-2008, 05:37 PM   #7
I was running the same size tires on my Max. I rubbed in front, but never in back. I had them setup just like they were on the Z
__________________
OEM RIMS FTW!
Old 08-04-2008, 12:37 AM   #8
Are you sure? I recall the fronts are 8 and rears are 8.5 or am I mistaken?? I know the offsets are +30 front and back.
__________________
Old 08-04-2008, 12:39 AM   #9
FRONT - 225/45/R18
REAR - 245/45/R18
Thanks guys!
Matt
the aspect ratio (sidewall size) are one size too large. your speedo and odo will be off as the diameter of the tire is larger than OE 4th gen specs. it will fill in the gap nicely but its not to spec. run these if you like, but id get the right tire size nonetheless. 235/40-18 would be most preferable.
__________________
Old 08-04-2008, 08:48 PM   #10
Quote:
I am pretty sure they are 18x8 +30 all around just like the 7spoke G wheels.
The 2nd gen 5spoke touring wheels are staggered 18x8 +30 and 18x8.5 +33.
Old 08-05-2008, 08:29 AM   #11
Quote:
How much were you lowered front / back?
Funny thing about that is, my speedo is dead on now, it must have been off before.
And the setup actually only raises about around .90 (almost an inch) from stock setup.
I haven't got the money to put the 'ideal' tire on so that is a no go.
Like I said, I've raised it about 1" from stock just by installing the tires, shouldn't I be able to lower it at least 1.5" ??
__________________
______________
Old 08-05-2008, 11:12 AM   #12
Send a message via AIM to Hexon
You would have to have some stiff springs or struts. If you have any body roll you could rub the fenders. I think you need to roll your fenders
__________________
Hexon is offline   Reply With Quote
Old 08-05-2008, 08:54 PM   #13
Maybe I'll dish out the cash for adjustables, I'm in Canada too so its gonna be low on the winter tires, and then I've got some room to play so I can find the right settings.
More money than I was planning on spending though.
So far this is not the good news I was hoping for!!!!
Thanks for replies though guys.
Matt
__________________
______________
Old 08-05-2008, 08:59 PM   #14
I am some where down 2+ inches.... umm see sig is all I can say. I don't have an exact measurement.
__________________
OEM RIMS FTW!
Old 08-07-2008, 12:56 AM   #15
^thanks man,
that helps, I think I'm gonna be safe with the 1.5-2" drop
__________________
______________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
