Go Back   Maxima Forums > Maintenance, Tech, & Care > Tires and Wheels
Thread Tools Display Modes
Old 06-21-2008, 08:31 PM   #1
Why won't these 5x114.3 wheels fit on?
I bought some Mille Miglia wheels today and i just did a dry fit with no tires to see what they'd look like and when i went to mount the rim it would not go all the way on. There is a ring inside the wheel that won't fit over my brake caliper. . .does any1 know what this is all about?
Here are some pictures.
__________________
1997 Maxima SE
5 Speed, White,
140XXX Miles
18" 350Z's
josh662234 is offline   Reply With Quote
Old 06-21-2008, 09:13 PM   #2
HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
__________________
1997 Maxima SE
5 Speed, White,
140XXX Miles
18" 350Z's
Old 06-21-2008, 09:28 PM   #3
a centering ring came on my MM Evo5 replica rims..
__________________
11/8/08 Eibachs + Illumina 5F/5R Equipped
FlipCpt45 is offline   Reply With Quote
Old 06-21-2008, 09:51 PM   #4
The LandShark has teeth..
grey99max's Avatar
Ditch the centering ring and try fitting the wheel again. The lug nuts do the work of holding the wheel centered anyway. Just torque the lug nuts correctly and carefully, and you should be good.
grey99max is offline   Reply With Quote
Old 06-22-2008, 12:22 AM   #5
thanks guys this worked
__________________
1997 Maxima SE
5 Speed, White,
140XXX Miles
18" 350Z's
Old 06-22-2008, 08:31 PM   #6
You need to get a set of hubcentric rings for a Nissan to replace the ones you removed. You can try www.discounttiredirect.com they sell quality metal hub rings. Hubcentric wheels are designed to be supported by the hub, the lug nuts just hold the wheel on the hub.
__________________
click here for more pictures
z32drifter is offline   Reply With Quote
Old 06-22-2008, 09:55 PM   #7
Your are going to need the proper sized centering ring as said above. I ran my car for an hour without them and took the wheels right off until the rings showed up.
__________________
PulsarGTS is online now   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
