Go Back   Maxima Forums > Maintenance, Tech, & Care > Tires and Wheels
Thread Tools Display Modes
Old 06-15-2008, 09:18 PM   #1
18 x 9 +15-4th gen-rears-how much roll?
I was thinking of picking up some mb weapons with 9 width and low offsetts for the rear. The front will be 18 x 8 +30 and the rears will be 18 x 9 +15. I wanted to know if anyone has similar offsetts for the rear wheels? I will be putting this on my 4th gen.
Pics would be appreciated. I'm sure the rears will have to be rolled. I want to achieve flushness with a concave face. The only way, it seems, is with a low offsett and/or a high width(9 or 10inch).
RIPTIDER is offline   Reply With Quote
Old 06-15-2008, 09:36 PM   #2
You'll need some low pros and stretched tires.
That size might poke out a little bit.
IHAVEA2KMAXIMA is online now   Reply With Quote
Old 06-15-2008, 11:39 PM   #3
Send a message via AIM to MrDicks95SE
Youre going to have to roll and run stretched tires.
My old setup 18x9 +13 (25mm spacer) with 225/40 tires:
__________________
MrDicks95SE is offline   Reply With Quote
Old 06-16-2008, 08:53 AM   #4
A32shop.com
BLACKonBLACK98's Avatar
Send a message via AIM to BLACKonBLACK98 Send a message via MSN to BLACKonBLACK98 Send a message via Yahoo to BLACKonBLACK98
looks like a good size depending on how low you are dropped. it should be ~.5" of poke which should look ok if you're not too low (rich's pics are a good example). run some mild stretch on the tires and roll the lips flat (maybe even pull a little).
__________________
Under Reconstruction
My CarDomain
Houston Maximas
BLACKonBLACK98 is offline   Reply With Quote
Old 06-16-2008, 11:34 AM   #5
I would've preferred not to stretch the tires but it looks like it is unavoidable with the current wheels spec.
I wanted to know, you guys stretching the tires, it dosen't freak you out that, if you run into a pothole that your wheels will get damaged? Correct me if I'm wrong, but it just looks like you are more prone to damaging your rim lip.
Or is that the pros and cons with setups like this? Similiar to slamming your car and worrying about scraping curbs and speed bumps?
Old 06-16-2008, 11:59 AM   #6
A32shop.com
there are no pros other than being able to fit better fitting wheels. ppl who stretch are usually people who are obsessed with fitment, but recently some ppl have been treating it like it's own styling cue (which is ok too) and stretching more than/when not necessary. to run the specs you want stretching is pretty much unavoidable (depending on your drop).
__________________
My CarDomain
Houston Maximas
Old 06-16-2008, 01:13 PM   #7
i get scared ****less with my 19s... especially with the nasty potholes and ruts in the roads.
i pray to car god that no bend in wheel.
__________________
Old 06-16-2008, 04:52 PM   #8
Is all that wheel rash from stretching? I doubt that came from curbs.
Old 06-16-2008, 04:57 PM   #9
OR this could happen
shame........
Old 06-16-2008, 05:19 PM   #10
Quote:
no the previous owner f-ed em up.
__________________
Old 06-16-2008, 05:22 PM   #11
SSRs only have the center semi forged. the lips arent. can be referred to "Super Soft Rims"
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
