Go Back   Maxima Forums > Maintenance, Tech, & Care > Tires and Wheels
Thread Tools Display Modes
Old 06-12-2008, 10:50 AM   #1
would staggered wheel fit 02-03 maxima
im looking to put 19x8.5 in the front and 19x9.5 rear
would they fit and what would offset would work best
97lopezMax is offline   Reply With Quote
Old 06-12-2008, 01:09 PM   #2
A32shop.com
BLACKonBLACK98's Avatar
Send a message via AIM to BLACKonBLACK98 Send a message via MSN to BLACKonBLACK98 Send a message via Yahoo to BLACKonBLACK98
yes.
__________________
Under Reconstruction
My CarDomain
Houston Maximas
Last edited by BLACKonBLACK98; 06-14-2008 at 11:38 AM. Reason: did not see the year.
BLACKonBLACK98 is offline   Reply With Quote
Old 06-14-2008, 03:29 AM   #3
They would technically fit but baby jesus would cry
__________________
All stock.
MorpheusZero is online now   Reply With Quote
Old 06-14-2008, 11:38 AM   #4
A32shop.com
wtf?
__________________
My CarDomain
Houston Maximas
Old 06-14-2008, 12:19 PM   #5
Quote:
Originally Posted by BLACKonBLACK98 View Post
wtf?
I'm back baby!
__________________
All stock.
Old 06-14-2008, 01:01 PM   #6
Quote:
I'm back baby!
Personally I'm not sure if I would EVER stagger with a maxima, but if you really want to, +35mm offset all around with those widths will work perfectly. You will have to roll your rear fender for clearence under compression...
__________________
Fast1one is offline   Reply With Quote
Old 06-14-2008, 01:20 PM   #7
A32shop.com
I'm back baby!
Quote:
Originally Posted by Fast1one View Post
:... +35mm offset all around with those widths will work perfectly.
that was my answer to until i noticed 02-03. don't they have a bit more room? maybe a +30?
__________________
My CarDomain
Houston Maximas
Old 06-14-2008, 02:45 PM   #8
Certified Hooptie
NmexMAX's Avatar
Send a message via AIM to NmexMAX Send a message via MSN to NmexMAX Send a message via Yahoo to NmexMAX
I have 8.5" / +18 on mine and she hardly ever rubs, only on 1 side over horrid bumps.
__________________
03 SE 4AT 242whp/238wtq
95 SE 4AT 235k Miles
NmexMAX is offline   Reply With Quote
Old 06-15-2008, 01:42 AM   #9
Send a message via AIM to MrDicks95SE
dont be weak sauce. fill in that wheel well gap.
for those sizes (8.5 and 9.5) go +20 all around. definitely flush.
__________________
MrDicks95SE is offline   Reply With Quote
Old 06-15-2008, 02:09 AM   #10
wow how does that not rub???
__________________
99 i30
07 rx8
02 sv 650 v-twin
se_nismo is offline   Reply With Quote
Old 06-15-2008, 02:20 AM   #11
Yes you can put stag fit rims. I did a few before axis sell a nice set up but i only did 20s. they were 20.8 frt and 20.9 ashanti wheel they look nice but you have the rotation issue and tires arent that cheap 225 30 in the front and 265 or 275 30 20 in the front lowered and roled fenders my wife had that one but it was stolen in fl
__________________
Fastest se-r in AZ
http://s220.photobucket.com/albums/dd218/BahamasSR20
BAHAMASSR20 is offline   Reply With Quote
Old 06-15-2008, 02:27 AM   #12
Send a message via AIM to submaxzero Send a message via Yahoo to submaxzero
MR D. wow B thats wat u call threadin da needle like magic is his prime
submaxzero is offline   Reply With Quote
Old 06-15-2008, 06:11 AM   #13
8.5 +20
Go for +35 unless you're going to be putting 205s on them.
__________________
All stock.
Old 06-15-2008, 01:30 PM   #14
8.5 +20
Agreed, put some fatty tires if you are going to stagger. Personally, I would do 265 rear/245 fronts
__________________
Old 06-15-2008, 03:09 PM   #15
can you also tuck the rear with 9.5??? i was thinking about getting the RPM rims from our GB but dont know if my staggered steup will work...
__________________
Fully Equiped " It's a Maxima world
_____________________________________________
I finally got my maxima... Just wait til you see me at a major car show, i promise to surprise and turn heads
SHIFT_by itself
DCMAX
Update- I'm officially fed up with auto tranny... 5spd swap for me
Grand_hustle17 is offline   Reply With Quote
Old 06-25-2008, 08:27 AM   #16
so should the offset be 35 or 30
Old 06-25-2008, 08:45 AM   #17
Certified Hooptie
NmexMAX's Avatar
35 for the rears, 30 for the fronts.
__________________
Old 06-26-2008, 10:01 AM   #18
Quote:
you said that your car rubs on one side right my car rubs only on the rear passager side only.i have the g35 18s on it right now
Old 06-26-2008, 10:39 AM   #19
Certified Hooptie
NmexMAX's Avatar
Quote:
And your point?
In order for me to validate this comment, I need a little more information from you.
1.) What size tires are your G wheels wrapped in?
2.) We all know, or should know, the reason for only rubbing on 1 side, mine too rubs only on the passenger side w/ 8.5" wide / +18mm.
__________________
Old 06-26-2008, 10:41 PM   #20
Quote:
uh what?
8.5 +20
alright 8.5 +30-ish for the sake of meaty tires. 245 fronts. rears need to be low offset tho
__________________
Old 06-26-2008, 11:20 PM   #21
Send a message via AIM to Hexon
curious, but would a staggered wheel mean that you could not rotate the back wheels/tires to the front when the fronts get worn out?
__________________
Hexon is offline   Reply With Quote
Old 06-27-2008, 01:42 AM   #22
Certified Hooptie
NmexMAX's Avatar
what it means!
__________________
Old 06-27-2008, 12:37 PM   #23
that's not very economical. But I suppose you wouldn't have to replace the rear tires as often.
Old 07-02-2008, 05:50 PM   #24
so it got cut off for some reason
well i have 245/45-18 rear and 225/45/18 front
im not sure on the offset
but it rubs on the passager side only
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
