Go Back   Maxima Forums > Maintenance, Tech, & Care > Tires and Wheels
Thread Tools Display Modes
Old 06-10-2008, 10:52 AM   #1
I can has VLSD 5-speed!?
Pearl93VE's Avatar
Send a message via AIM to Pearl93VE
I had a few questions
There is a rim/tire setup near me and I'm wondering if anyone has ran the setup, or similar.
Rims:
They're Motegi Racing RT5 Rims.
Aluminum
18"x7.5" D/W
+45 Offset
5x114.3 BP
66mm Center Bore
Tires:
Toyo Tires (Not sure if they're proxies, but there is a picture below)
235/40/18
They were on a 4th gen so It appears they fit that, but I'm curious as to if they'll run on a dropped third gen. (Eibach/Tokico 1.2" drop all around)
It is for a price I cannot pass up.
__________________
Pearl93VE is online now   Reply With Quote
Old 06-10-2008, 11:25 AM   #2
A32shop.com
BLACKonBLACK98's Avatar
Send a message via AIM to BLACKonBLACK98 Send a message via MSN to BLACKonBLACK98 Send a message via Yahoo to BLACKonBLACK98
yes they will fit.
i don't know why people think that just because its wheels/tires they don't need to search.
1) i'm POSITIVE this size has been covered before.
2) measuring is not hard
3) we're talking mm here. this is what; like 5mm more sunk in than oem sizes.
4) theres not much you can't fit with irs.
__________________
Under Reconstruction
My CarDomain
Houston Maximas
BLACKonBLACK98 is offline   Reply With Quote
Old 06-10-2008, 11:34 AM   #3
Flopaholic
ROCKART's Avatar
Send a message via AIM to ROCKART
235 is pretty wide for a 7.5 wheel
is that picture the actual wheel?
if so, im guessing they are either NOT 7.5 wide or not 235 tires (probably not 7.5 wide)
the recommended sizing for a 7.5 18inch wheel is 215, at most 225. 235s would hang like a bich
ROCKART is offline   Reply With Quote
Old 06-10-2008, 11:45 AM   #4
A32shop.com
tires vary a lot from model to model. toyo are on the narrow side of the spectrum. 40 series also lessens the bubbliness.
1cm (/2) will not cause something to "hang like a bich".
where are you getting your recommended sizing? you have to remember that most websites will give you a recommeded size based on diameter not width. ftr, 235 is recommended for a range of 8-9.5.
__________________
My CarDomain
Houston Maximas
Old 06-10-2008, 12:01 PM   #5
Pearl93VE's Avatar
I tried searching but none of it is 3rd gen specific really... 45+ offset is a little high for 18's I thought, but I'm not really experienced with what these car's can, or can not ride with without rubbing.
Right now I have 16x7" BBS RX's with 225's on it and 50 height and they run fine, so I'm not worried about the tires not fitting right. Either way, the guy only wants $100 for everything so at the least I could just re sell them or trade for something I need.
Yes, that is a real picture of the rim/tire setup btw.
__________________
Old 06-10-2008, 12:06 PM   #6
Flopaholic
ROCKART's Avatar
100 for everything?
id buy it, try them on, see how you like them, and then sell them for 300-400 on either CList or here....
you cant go wrong for that price.
it almost seems suspiciously cheap. make sure they are not bent or warped before the purchase.
Old 06-10-2008, 12:07 PM   #7
A32shop.com
sometimes you have to look for less than specific info and use your head a little. take the largest wheel youve seen fit and use that as a base. then a little simple math (or online calculator) wil give you your answer.
but yeah... they will fit.
__________________
My CarDomain
Houston Maximas
Old 06-11-2008, 01:02 AM   #8
Send a message via AIM to MrDicks95SE
a lot of people here obviously cant do that. its a sad thing.
__________________
MrDicks95SE is offline   Reply With Quote
Old 06-11-2008, 10:48 AM   #9
Pearl93VE's Avatar
Quote:
It's because I've been told such contradictory evidence... And no matter what you search, you get different answers every time. You guys with 4th+5th gens have it easy because everything has been covered a million times, but a 3rd gen is a different car; I was hoping someone would have wheel/tire knowledge on them since many people obviously don't, so that's why I posted in this section as well.
Over in the third gen forums I've started a thread too:
3rd Gen Wheel/Tire Setup Questions
And they're all saying that they won't fit, where as here everyone is saying they will. I guess the only true way is to ask the guy if he'll let me test fit before purchase. I can't search if there's no definitive answer on what will fit on our car's or not. (What would I be searching for exactly?) But apparently I'm going to need spacers anyway.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
