Tires and WheelsRubber, and lots of rubber in all kinds of sizes. What do you use when it's freezing? What do you use when it's hot? You want sticky rubbers? How about rubbers that will last a long time? Find your perfect rubber in here.
hey guys im looking at getting a set of wheels with a 40mm offset thats 19x9....will these fit on the 2k2 while running a 245/35/19 tire without problems???
they come in 19x8 tho also but i want^^^
i think you would rub unless you roll your fenders.
if run 245s i rub...
__________________
--Jon-- Currently driving: 03 Maxima: 40k miles, Bodykit, CF hood, 20'' Chrome DUBz, Alarm, Tint, Eclipse AVN6500, Rainbow Profi Vandiums, Boston Pro60s, 2 12'' Type Rs, Suspension, Cleared 8k HIDs w/ DDE Angel Eyes, Intake, Exhaust, Timing Adv, Custom 2 Tone Interior, x drilled/slotted/zinc rotors, SS brake lines, etc. 92 Max SE: 5 speed LSD 230k Daily Driver FTW 4DSC!!!! Retired: 97 Max modded: BURNED IN FLAMES 96 Max modded: Sold to brother 95 Max modded: Attacked By Volvo
Quote:
Originally Posted by KRRZ350
I'm the only one showing my e-manliness to compensate for my small penis size.
Ive got a mild drop on H&R Springs....im running 245/35/19 tires and 19 inch rims with a +38 offset
Does any one think ill begin to rub over time...so far i dont think im rubbing, i dont see any damage or anything on the tires....in the rear, but as time goes on do you guys think ill be ok
__________________
Tokico Illumina's 4F/5R | H&R Springs | ebay FSTB | Progress RSB (need 2 install) | ES Bushings | Goodridge SS Lines | Berk Air Intake | Cleared 2K2 Headlights | 8k D2R and 50W H3 Fogs upgrade | Cleared Sidemarkers | White LED's all around (Interior & Exterior) | Chrome Gauge Rings | 15% Tint (all around) | RTP Zinc plated Slotted Rotors | Hawk HPS pads | RPM R-505 19x8.5 wrapped in General Exclaim UHP 245-35-R19 | Optima Yellow Top | Hella Supertones | (2) 12" Alpine Type R's
I'm on 8.5" +18 and rub on very rare occasions. W/ the +38, I'd say you're fine.
__________________ 03 SE 4AT 242whp/238wtq
95 SE 4AT 235k Miles
You'll likely be fine. I was running 19x9 +30's on my 4th gen with 255/35's and only experienced mild rubbing on one side in back. Tire profile will also have a little bit of an effect on whether or not you rub. But with a +40, I wouldn't worry.
__________________
Current Car '06 IS350
Old Car
Evolution Autodesign Turbocharged '97 GXE Auto
19x9 2 Piece G-Games Wheels | Custom Candy Blue Paint | So much more....
301whp/312.4ft-lb torque @ 7psi | 13.8@105mph
