Go Back   Maxima Forums > Maintenance, Tech, & Care > Tires and Wheels
Thread Tools Display Modes
Old 06-04-2008, 06:05 PM   #1
225/45/18in tires ON A 18x9 rim??
anyone has pics of this??
nycmaximakid is offline   Reply With Quote
Old 06-04-2008, 08:40 PM   #2
mad tyte JDM drift king
irish44j's Avatar
go wider. That size belongs on a 7" wide rim, not a 9" wide rim.
stretching tires is lame.
irish44j is offline   Reply With Quote
Old 06-05-2008, 12:46 AM   #3
RIP Cashj2002
Delvin's Avatar
Send a message via AIM to Delvin
Quote:
And so is rubbing when running wider wheels with fat rubber.
If you dont mind me asking is there a reason you are going for a mildly stretched look or are you doing it for clearance issues?
__________________
Family Photo
Delvin is offline   Reply With Quote
Old 06-05-2008, 09:12 AM   #4
yer gonna need at least a tire width of 235mm for a 9" wide wheel...
__________________
"MAXI 2 ENVY"
LudaTej is offline   Reply With Quote
Old 06-15-2008, 12:34 PM   #5
i have 255-30's in the rear now with a sport drop and dont have any rubbing or clearance problems.
so since i have to change my rear tires since there almost done i rather go for a stretched look like on my dub plus the tires would be way cheaper.
so im guessing 225-40's for the front 18x8
and 235-40's for the rear 18x9 ??
Old 06-15-2008, 11:44 PM   #6
Send a message via AIM to MrDicks95SE
225/40-18
__________________
MrDicks95SE is offline   Reply With Quote
Old 06-16-2008, 12:17 AM   #7
loks good.^^^
__________________
*Cheap T-mobile Phone
http://forums.maxima.org/other-sale-...-t-mobile.html
Nov-2008
*2002 SE 45K Springs
http://forums.maxima.org/5th-generat...ml#post6626906
Nov-2008
Snypa is offline   Reply With Quote
Old 06-16-2008, 02:10 AM   #8
ptviperz's Avatar
Not feeling that at all. Go wider, not stretched.
__________________
03 SE/TE 6M w/HLSD: 350Z wheels, Progress RSB, FSTB, ES bushings, STS, MR CB, 18% tint, HID 8K fogs
ptviperz is online now   Reply With Quote
Old 06-16-2008, 08:01 AM   #9
essential1's Avatar
Quote:
The idea is to stretch the tire to prevent rubbing. Run a wider tire and you'll rub all day.
__________________
essential1 is offline   Reply With Quote
Old 06-16-2008, 10:08 AM   #10
ptviperz's Avatar
Quote:
I guess I'm old school I'd run the right width wheel. instead of a 10" width and stretched tire.
__________________
Old 06-16-2008, 10:52 AM   #11
A32shop.com
BLACKonBLACK98's Avatar
Send a message via AIM to BLACKonBLACK98 Send a message via MSN to BLACKonBLACK98 Send a message via Yahoo to BLACKonBLACK98
stretching tires for the sake of stretching is lame.
fixed.
stretching tires because you are so low and running well fitting wheels means you are cool. in the op's case i would say don't do it since you are not experiencing any problems with your current setup.
__________________
Under Reconstruction
My CarDomain
Houston Maximas
BLACKonBLACK98 is offline   Reply With Quote
Old 06-16-2008, 10:53 AM   #12
to answer your question yes it will work/fit
phatboislim is offline   Reply With Quote
Old 07-19-2008, 11:38 AM   #13
thanks so i guess to play it save and still have a stretch look i will go with
225-40-18 for the front 18x8
235-40-18 for the rear 18x9
Old 07-19-2008, 09:12 PM   #14
A32shop.com
just get the right size (255 or larger). 225 or 235 is good for the front. you're not low enough to necessitate stretch.
its already hard enough on us stretch guys, don't make it worse by doing it for no reason.
__________________
My CarDomain
Houston Maximas
Old 07-20-2008, 04:07 AM   #15
word.
__________________
Old 07-20-2008, 08:54 AM   #16
my car is low and i dont like how 255-30's looks which is what i have and will need to change soon. not worth to spend more money on that size tire.
Old 07-20-2008, 08:26 PM   #17
A32shop.com
spring drop /= low. but do whatever then.
__________________
My CarDomain
Houston Maximas
Old 07-20-2008, 08:57 PM   #18
Stretched tires makes it look like you couldn't afford the proper sized tire... jus sayn tho
__________________
PulsarGTS is online now   Reply With Quote
Old 07-20-2008, 09:51 PM   #19
Send a message via AIM to kzoosho Send a message via MSN to kzoosho Send a message via Yahoo to kzoosho
Quote:
Im running 225/40/19's on a 8.5 rim. Doesnt look bad but keeps me from rubbing more.
__________________
99 GXE Auto V1 370cc injectors and Modded vb.
97 5sp SE New build Holset HX52 and spray. More to come.
91 GXE Auto bone stock beater
Led retro's Pm me
kzoosho is online now   Reply With Quote
Old 07-22-2008, 12:01 AM   #20
uh what??
having an unpainted front lip makes it look like you cant afford a simple paint job. just sayn tho.
__________________
Old 07-22-2008, 02:58 AM   #21
I R The Law
The Law's Avatar
Send a message via AIM to The Law Send a message via MSN to The Law Send a message via Yahoo to The Law
Quote:
Originally Posted by MrDicks95SE View Post
uh what??
HAHAHAHAHAHHAH!!!!!!!!!!!
__________________
Myspace
Progress Coilovers, Otto racing FTSB, Stillen RSTB, Progress RSB, Window tint 5% All Around, Clear Side Markers, Berk w/ JWT Filter, SS brake lines, 350z Ray Rims, Maxxtuning front lip, Stillen sides and rear lip, 300z BBK, SSIM, Xtreme Eyelids, NWP Thermal Intake Manifold Spacer, Truax SFCs, E46 DDE's, Clear Corner, JL W3, Rainbow speakers, Eclipse AVN 6610, Hifonics amp, Epic 160, HS Headers
The Law is online now   Reply With Quote
Old 07-22-2008, 03:01 AM   #22
I R The Law
The Law's Avatar
So many hates in the club
__________________
Myspace
Old 07-22-2008, 03:21 AM   #23
Quote:
u know it. we <3 the org.
__________________
Old 07-26-2008, 08:53 PM   #24
Send a message via AIM to MIK3
You shouldn't have rubbing issues with even a 245 tire assuming you aren't going lower than 1.5". However, if you decide to stretch, watch those lips. One curb and say goodbye to your wheel.
__________________
MIK3 is offline   Reply With Quote
Old 07-26-2008, 09:30 PM   #25
HandyMan
SurraTT's Avatar
Send a message via AIM to SurraTT
check my sig.
245 45 18
but i guesss im 18X8 idk 4 sure
personally i dont like it, i had to roll rear fenders and they still rub, front rubs when bottom out. and when turn kinda rubs splash
im lowered on maxspeed, and stock struts
edit, jus realised the sig pic was stock rear springs. its fine on stock springs but not maxspeeds, jus havent switched back yet
__________________
4DSC
www.MECCWorld.com
HAVE:
2002 SE 6 Speed KH3, black leather
2002 SE Auto , black leather
2006 Kawasaki Ninja 250R noob!
1985 300ZX 5 Speed White For SALE!
HAD:
1992 SE Auto Aztec Red
1992 SE 5 Speed KH3
1990 SE 5 Speed Parts car
1987 SE 5 Speed Started it all!
Blacked out window trim / G coupes / BFG g-Force T/A KDW2 (245 45 18) / Maxspeed on stock struts / Tinted=fogs+sides+tails / Subframe Connectors / Flowmaster / Test Pipe / 20% windows / NWP Intake spacers (1st set ever for VQ35!) / Fidanza / Spec V tranny / HR Clutch / NWP Vias plate / Custom 12Volt XBOX, modded / Kenwood DDX6019 / ///////////
SHIFT_Clean and Crisp
Cardomain
SurraTT is offline   Reply With Quote
