Tires and WheelsRubber, and lots of rubber in all kinds of sizes. What do you use when it's freezing? What do you use when it's hot? You want sticky rubbers? How about rubbers that will last a long time? Find your perfect rubber in here.
Wheel/Tire Sizing Experts? 245/40 on a 7.5" Wide Rim?
I just upgraded from the OEM Gen4 16" rims to 18 x 7.5s off an 03 Infiniti M45. The original equipment Infiniti tire on this rim is a 235/45/18.
I'd like to run a wider tire but still stay reasonable as far as a change from the OEM overall diameter. The tire Ive found to be most desirable to me is a 245/40/18.
In shopping for that size tire (245/40/18) I'm finding that the acceptable rim width is 8.0 to 9.0.
Whats got me a little perplexed is the fact that in looking at some of the application tables for various tires, some state that the acceptable rim width for a 235/45/18 (the OEM size) is also 8.0 to 9.0.
That being said and knowing that, in fact, the manufacturer put a 235/45/18 tire on a 7.5 wide rim, would everyone think it would be safe to install a 245/40/18 tire on a 7.5 wide rim?
btw, different tires from different companies have different specs depending on sidewall construction and stiffness - hence why some will fit that size and others say they won't.
I would NOT put that tire on a 7.5" rim. As the ratio increase (40 to 45) you get more leeway on the width of a rim you use. So you can use a 235 on a 7.5" rim in a 45 ratio, but shouldn't with a 40 ratio. Even more so with a wider 245mm tire. If you had a 50 ratio, you might be able to stick it on a 7.5" rim, but I wouldn't put a 40 on that rim. Safety and Specs aside, it wouldn't look good at all. You can put a 235/45+ or a 225 in any ratio on that 7.5" rim. You need an 8" rim for a 245/40. Keep in mind -wider tires are better traction, but lower gas mileage.
I just purchased some OEM 350Z Touring V.1 18's for the max. I was planning on getting some 225/45/18's for the front, and 245/45/18's for the back because of the offsets, should i instead get 235/45/18's for the back as you told turbobink?
What is the width of those rear rims? If it's 8 or 8.5" than either the 235 or 245 will probably fit. He was trying to install a 245/40/18 tire on a 7.5” wide rim -a wider tire, and smaller rim than your combination. FYI - a 225/45/18 is 26" diameter, a 235/45/18 is 26.5" diameter, and a 245/45/18 is 26.7" diameter. Your back wheel will be slightly larger than your front regardless.
