Tires and WheelsRubber, and lots of rubber in all kinds of sizes. What do you use when it's freezing? What do you use when it's hot? You want sticky rubbers? How about rubbers that will last a long time? Find your perfect rubber in here.
I am having a hard time finding out what they are...
Any help would be greatly appreciated!
-Matt
__________________
--1997 Maxima SE, White Frost Pearl Ext/Black Int/5spd: 15% Tint all around,Optima Red Top Battery, upgraded audio, Brembo Slotted Rotors all around, SS Brakelines, CE SS Y-Pipe, SS clutch line Place Racing CAI, K&N Conical Air Filter, Street Scene aluminum grille Audio- Alpine CDA-9887, DLS Iridium 6.3's, Blaupunkt Velocity tweeters, Eclipse XA4000, TC 2000 12D4, sealed 2.0 cu.ft., Eclipse DA7122 mono amp
--1979 Ford Bronco XLT(HEAVILY MODDED,pic of engine in avatar), Deep Forest Green Metallic w/blue pearl(custom paint): 7.6L V8-600hp/650lb.ft(ALL MOTOR)~5000lbs, 0-60~4sec. 'BIG PIMPIN' WILL outrun your Maxima(& mine)
Thanks guys, I think I will be getting a set for my Max
Now, to only find some 10mm rear wheel spacers...
-Matt
__________________
