Go Back   Maxima Forums > Maintenance, Tech, & Care > Tires and Wheels
Thread Tools Display Modes
Old 06-20-2007, 02:41 AM   #1
Mr.Duck's Avatar
Send a message via AIM to Mr.Duck Send a message via MSN to Mr.Duck
hub bore question
So i bought a set of rims that one fit on the maxima unfortunately, the hub bore is too small on the rims. i believe it came off of a is300 which hub bore is around 60.1mm and ours is 66.2mm
my question is, are there any options to be able to use the rims? or am i pretty much screwed?
__________________
Modifications:Cattman Y-pipe, Motostorm UDP, Blehmco Ground Kit, SS clutchline, Autovation Aluminum Pedals, Otto Racing FSTB, Ksport Coilovers, SRE Short Throw Shifter, 00vi
14.521 on street tires
14.42xon drag radials(will update when i get my slips outa my car)
Chicago members!!!!
http://www.chicagomaximaclub.net/
Mr.Duck is offline   Reply With Quote
Old 06-20-2007, 03:15 AM   #2
that is a tough one. i am far away from being an expert in this but i cant imagine a solution. usually u can get hubcenteric rings if the bore of the rim is bigger than the bore on the car to fill the gap but in this case, you need to do the opposite. i doubt shaving the inside of the rim is a good idea. lets see what the experts recommend.
VIP Maxima is offline   Reply With Quote
Old 06-20-2007, 05:40 AM   #3
Very sound, Mike
Wheel hub adapter maybe? Although i don't think one is made for our cars.
soundmike is offline   Reply With Quote
Old 06-20-2007, 10:29 AM   #4
Mr.Duck's Avatar
anyone else got any ideas?
Old 06-20-2007, 11:40 AM   #5
Let's build something!
oldngivout's Avatar
Titan wheels can be made to fit the older Hardbody trucks by simply having a machine shop bore the center hole out to match the hub. They are on Ebay everyday.
I don't see why you could not do this to the Lexus wheels. Problem is cost. Custom machining is not exactly cheap. Maybe by doing all four, the cost per wheel could be justified, especially if you got a good deal to begin with. Set-up cost would be high on the first one, but would average out with four.
oldngivout is offline   Reply With Quote
Old 06-20-2007, 12:02 PM   #6
Wild for Width
Fr33way™'s Avatar
Send a message via AIM to Fr33way™
You can bore these out to 66.1. A 3rd genner did it and it looks sweet. 66.2 is usually the diameter given for centering rings or spacers (so they fit).
__________________
Fr33way™ is offline   Reply With Quote
Old 06-20-2007, 08:07 PM   #7
Mr.Duck's Avatar
so boring it out is really my only option right? spacers wont do anything for it?
ugh.. anyone know a machinist in chicago? lol
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
