Question about spacers
Driving around the city a week or so back I saw a Toyota Highlander (yes I know it looks nothing like a Maxima) that had a nice set of rims on it. Too bad I was driving my F-250 (Way too big to be a Maxima I know) and couldn't get a good look at the brand, mainly because I was sitting way to high to see it. But I did get a good look at the style. Well finally I found it online today.
But a small problem came up when I started looking around for the cheapest price. According to one site, my backspacing now is 18mm, and the rims I'm looking at only have 2mm. So the need for a spacer has came up. I should have known considering the tires stuck out a little.
So my question is, what are some of the adverse of effects of running spacers? I'm going with a slightly wider rim than stock, but the same diameter.
I think you're stressing too much about it. How wide is the rim and what is the offset? My rears barely clear my trailing arm, especially with the sway bar bracket jutting out. I can barely fit a pinky finger between the tire and bracket.
And with spacers, the only adverse effects I've heard are that it moves the center of rotational mass away from the hub, putting extra stress on the wheel bearings. Something along those lines.
Opps my bad... got lost in rim technical terms. Plus I was about half asleep when I wrote the first post.
The stock rim is 16x6.5 w/ (+ or - ?)18mm offset (not back spacing)
The rim I want, 16x8 w/ +2mm offset
Well I was about to put the picture up, but it's really huge, about life size anyway, it's an Eagle Alloy 146
http://www.jdwheels.com/images/eagle%20146.jpg
Unclejunebug
04-02-2016 05:42 AM
