9.0 inch wide in front 4th gen
Anyone running 9" wide in the front? I know 8.5" with +30~+33 offset fits okay, but does anyone run 9" wide in front? If so, what offset? Any rubbing on full lock?
Originally Posted by Kevlo911
Progess springs, but drop has nothing to do with it.
275 tires
275 tires
Maybe it will work with a drift-style stretched 235 tire.
Originally Posted by limsandy
Stock offset is +45 to begin with.... unless you want the rims sticking out of the fender, which is
Originally Posted by z32drifter
I've run 17x9 +34 with a 255/40/17 with no rubbing. I would increase the offset since +34 sticks out a few mm in the front, looks perfect in the rear.
same wheel I'm running in my sig.
Originally Posted by 98SEBlackMax
Cool im looking to run a 17 x 9 5Zigen wheel with +35 offset. Also with a 255/40/17 tire. Im still going to order only one wheel/tire for a test fit but now I feel confident it will fit. Did you have to roll the fenders or any of that to get them to fit?
Thanks z32drifter for the pics and info. With them sticking out like that I'm guessing you're not too slammed either.
These wheels are my track wheels for my Z32, so they don't stay on the car for long. I did notice that the rears would hit when going thru high speed dips, I'm sure rolling the inner fender edge would correct the minor contact.
As for not too slammed, my car is on S-techs with AGXs.
If you look in the link under my sig, there are some other photos there.
i just got some rims from a mustang for my 4th gen max, but they are 9.5 in wide with a 20mm offset, i put them on and they stick out in the back about an inch, and more in the front, it dosent look bad though, whats wrong with them sticking out? i was goin to add a spacer in the back to even them out
Shadow here with the custom blue turbo auto I think were running 17x9's +30 255 tires I believe. Talk to him.
http://forums.maxima.org/showthread.php?t=432570
I own shadows car now and it has 19x9 30 offset with a 255/35/19 tire and it sticks out a little in the front and rear, both rub a bit and the rear can't ride passengers cause it will rub like crazy.
Originally Posted by Spadezz
well i just got my rims mounted today, them things are hot!! how do i put pics up? btw, the wheels have a offset of 20mm, maybe thats why they're able to fit and they dont rub at all, my tire size is 255/35/18
shadow's max is nice man, good job. I haven't had my max lowered yet so the tires dont rub even with passengers, and sorry that page isnt available, the image code doesnt want to work and i have a million and one pics too!!
Finkle
09-27-2015 09:53 PM
wingsfan24
08-15-2015 07:35 PM
ViciousVQ30
08-05-2015 05:40 PM
