how wide rims for 255-45-17??
255/45R17s are spec'd for 8.0-9.5 inch wide rims. That said, I'd stay on the lower end but I'm betting it my still rub on a 4th gen.
Shadow, those are 50 series rims. You can put 255/65R17 tire in a 7 inch wheel and still be within specs. It depends on the aspect ratio.
Originally Posted by 6SpeedTA95
A 9? I've got 9s on my TA and 275's are about right and I could easily go to 295 on a 9 inch wheel....
9" wheel is min for 275/40 so that's the largest tire you should run on a 9.
<think about it a 275 is almost 11" wide>
I run 255/40s on 17x8.5 and 17x9 (track)
need your help for rims sizes
Thanks a lot
20s on a 4th gen....
These are approved with a 245/30 tire, you will want a spacer for flushness in the rear.
http://www.tirerack.com/wheels/Wheel...ll&sort=Weight
all other chrome 50lb bling master "dubs" are denied, don't even go there
↨↨↨↨↨↨These↨↨↨↨↨↨
My rule of thumb for street tires: keep the rim width within one inch of the section width. That a rule of thumb, a.k.a. a general guide, not an absolute requirement.
0m3nc0w
09-11-2015 05:21 PM
