235/45 or 245/45 (17's)
Old 10-29-2005, 08:22 AM
Very sound, Mike
soundmike's Avatar
Guys,
Between these two profiles, if you wanted to have a bit more "comfort" would you choose the wider or skinnier of the two?
I currently have 235/45's and though they're great, i'm still out of spec (speedo) and i'd really like to cushion the ride a bit more. I'm hoping the 245/45's will help a bit.
I've read that wider tires transmit more road feel but also soak up larger bumps better. Skinnier tires, though less road feel (i guess in a way, comfort) it doesn't do as well with larger bumps.
Thoughts?
Thanks.
(p.s. they'll be going on 7.5 or 8" wide wheels, so no issues there)
soundmike is offline
Old 10-29-2005, 10:55 AM
njmaxseltd's Avatar
These specs are based on the Avon M550 A/S which are going to be my next set of tires. Read the reviews on Tire Rack.
Stock 215/55/16 revs/mile = 821
Plus 1 235/45/17 revs/mile = 818
That doesn't throw the speedo off much at all, almost unnoticable. Going up to 245/45/17, which I'm thinking of doing also, puts you at 808 Revs/mile. Thats about a 1.6% lower speedo error, which isn't bad at all. It's less then 1mph at 60.
45% of 235 = 105.75mm tire height
45% of 245 = 110.25mm tire height
While being minimum, just about 5mm, I think the larger tire might fill out the wheel wells a bit more. And I do agree that ride comfort should go up ever so slightly because of the additional profile.
More tire = more cushion.
njmaxseltd is offline
Old 11-01-2005, 05:09 AM
Very sound, Mike
soundmike's Avatar
Thanks for the response
Actually, my numbers are just slightly different (2k2 Max) since the OEM's were 225/50's but the consensus is the 245/45's will be a much better match to the OEM's than 235/45. I'm just hoping the added width does add to some noticeable level of comfort.
Old 11-02-2005, 06:01 AM
350 Detroit Muscle
Ammi's Avatar
235s on 7.5" and 235 or 245s on 8" wide
Ammi is offline
Old 11-02-2005, 06:45 AM
I Know Kwaliti
igzy's Avatar
Good advice...
igzy is offline
Old 11-02-2005, 08:24 AM
Very sound, Mike
soundmike's Avatar
If the tire is within spec, what would happen if i put 245's on 7.5"?
Thanks.
Old 11-02-2005, 09:40 AM
I Know Kwaliti
igzy's Avatar
Tire would be much wider than the rim: potential risk of busting the walls, shifting belt, thread not square on the ground, not the best cornering... Something like that...
igzy is offline
Old 11-02-2005, 10:30 AM
Very sound, Mike
soundmike's Avatar
Thanks. I thought those risks were only if the tire was out of spec?
Looking at my 235's right now the rim is still sticking out so 245's may not be that bad. But we'll see.
Old 11-02-2005, 12:37 PM
I Know Kwaliti
igzy's Avatar
Considering that many ride on 235s with 7" rim, you still may be OK with 245s on 7.5" rim...
igzy is offline
Old 11-02-2005, 12:38 PM
350 Detroit Muscle
Ammi's Avatar
it's not recommended by many tire manufacturers but people still do it.
Ammi is offline
Old 03-01-2008, 09:34 AM
joebogey's Avatar
Hoping someone can help. I'm looking to get a set of Falken Ziex 912's for a 2001 Maxima SE, with OEM 17" rims. Looking at the Falken site, the OEM spec 225/50R17 have 805 rpm's, and fit 6"-8" wheels. I see that 245/45VR17 tires also have 805 rpm's , and fit a 7.5"-9" wheel. Since the rpm's are the same my speedo would still be accurate, but here's a stupid question since this is my father-in-law's car. What size are the OEM wheels, as I've seen them quoted as 7" and 7.5". And will the extra 2cm cause any fitment issues?
Thanks for any help.
joebogey is offline
Serotta33
09-17-2015 12:14 PM
Paulie Walnuts
10-09-2003 06:15 PM
Weave203
10-30-2002 01:59 PM
Marc2K
25
05-16-2002 07:08 AM
Quick Reply: 235/45 or 245/45 (17's)
