18" RSA Tire Pressure
Originally Posted by Albert
For the OEM 18" RSA, what psi are you guys running the tires?
(Assuming you're not going according to the manual)
i always ran 35 up front and 32 out back. ran this pressure on both my maxima and my grand am
Nations 1st 6th Gen Turbo
Open the glove box and look at the attached sticker, you need to follow the manufacters recommend tire PSI because they take into consideration the vehicles weight and handling characteristics.
Originally Posted by ramberg
If it not there, its under the top cover of the arm rest.
Based on an earlier thread on this subject, I am running 35 psi both front and back. It is a little higher than Nissan recommends, but should give me slightly better mileage with (IMO) little difference in handling.
I no longer have RSAs but Michelin Pilot Sports. I'm hoping the slightly higher pressure will also give me better wear on these tires than I would get at the lower pressures.
Finally, the correct pressure for an RSA will probably not be the same as for a Pilot Sport.
06-06-2017 02:01 PM
