350Z rims
350Z rims
Are all the 18 inch 350Z rims the same? 18x8 for the front and 18x18.5 for the rear... when I buy tires should i get the ones that match the factory tire size... 225/45/18 for the fronts and 245/45/18 for the rears.. please let me know.. cause I was just bout to buy some 245/40/18 tires...
Originally Posted by indecentmax
i've got 245/40/18 on all 4 corners dropped on h=tech' and have to problem with rubbing, azenis in front, and 555r's in the rear
That looks pretty good!!!
245-40-18 is the way to go.
Originally Posted by beefy23b/97
Does anyone have 350Z wheels on a 4th gen. If so pics?
im lookin at a set of 350z wheels with oem tires on my local craigslist. i assume they fit on my 95max because both have a 5 lug pattern. Do you think ill need to lower my car or will they look fine without it being lowered since they are 18s
well here they are. unfortinuately they dont fit flat against my rotors...theres a stupid metal cap sticking out. did anyone else notice this? (95 GLE Max) How did you deal with it? this will not do it may screw up my rotors/axel and a whole lot more
Iin more detail... my rotors look like the ones on this site..with the thing sticking out the middle of them
http://www.motorvate.ca/mvp.php/300
that prevents my wheels to go flat against the rotor and there is a gap between the wheel and rotor when its fully tightened (no way that flys). So, do i need new rotors? can i take that thing out?
i easilly fixed that problem by removing the pastic spacers. i couldn't see them in the dark when i first attempted to put the wheels on. these pieces of crap have been causing my stearing wheel to shake at high speeds even on the stock 15's. What kind of a moron would put plastic between a wheel and a rotor?
Originally Posted by Puppetmaster
He wasn't asking for an opinion as to which wheels look better, please stay on topic.
Haha yeah i know... this thread is to help me choose some tires for the 350Z rims that I ALREADY HAVE... but thanks for everyone's opinion on the rims but i'm still lookin for the answer on the tires... i'm just a little worried if the tires will rub or not since i'm lowered on tein s-tech springs... so i'm deciding if i should go 235/40/18 or 225/45/18.. i'm leaning towards the 235/40/18 since people have said it will look better and not stretched..
04-16-2020 05:15 AM
knight_yyz
11-01-2015 01:34 PM
