Wheels/tires Sticky? G35 wheels on maximas
Old 03-25-2006, 04:57 PM
  #201
retired moderator
irish44j's Avatar
Originally Posted by MFLCON
Hi,
I am talking to a guy with 7-spoke 17x7s off of a 05 G35 sedan (identical to the popular 18x8s off the coupe, but smaller). He says they have a 45mm offset. I know the coupe version wheels (18s) have a 30mm offset. Will this be a problem?
Thanks!
no...the maxima stock 17's are 42mm, IIRC, so they will fit about the same.
irish44j is offline
Old 03-25-2006, 08:53 PM
  #202
MFLCON's Avatar
Okay, I see. Thanks for your quick and helpful responses
MFLCON is offline
Old 03-27-2006, 12:19 PM
  #203
s0ber's Avatar
For those interested, I managed to stick a 240/40/17 tire on the G35 17's..
I have the coupe rims so there staggered... I put the rears in the front(17x8) with 245/40/17s and the 17x7.5 in the rears with 225/45/17.
the 245's look really nice, and its much more sensitive than it was before(switching lanes is a breeze now)...
I dont know if anyones done this with these so thought i'd post the info.
s0ber is offline
Old 03-28-2006, 04:32 PM
  #204
bluemax89's Avatar
I have the 17" '05 G Sedan wheels on my '89 Max, and they fit reasonably fine. Like I mentioned earlier, there is a tiny, tiny bit of rubbing that I notice when I turn the wheel to either extreme, but I am sure there is a simple way to get rid of it - just haven't had the time to make any adjustments. I'm sure they will fit well on later model year maximas.
bluemax89 is offline
Old 04-03-2006, 12:41 PM
  #205
Jules Maximus's Avatar
Okay, anyone know if 19" Infiniti M35/45 wheels will fit a 5th Gen Maxima?
Like these.
Jules Maximus is offline
Old 04-05-2006, 05:01 PM
  #206
MidnightMAX02's Avatar
I really like your maxima with those G35 wheels. looks HOT!!!
MidnightMAX02 is offline
Old 04-07-2006, 09:50 AM
  #207
Not for rookies!!
UnMaTcHeD's Avatar
I got a pretty good deal on a of 19 inch Ray's from g35driver.com.
Just wanted to say thanks for posting all the info about these wheels and providing the link to the g forums.
UnMaTcHeD is offline
Old 04-24-2006, 09:38 PM
  #208
Kadantsev's Avatar
Here's a bit of a stupid question,
What is the difference between Bolt Pattern 5/114.3 and 5/4.5? Will 5/4.5 fit 4th gen?
I'm trying to figure out if 18" M45 rims will fit my 98. Has anybody tried to use M45 or FX45 rims?
Kadantsev is offline
Old 04-25-2006, 06:15 AM
  #209
4 Maximas and counting
philpoe's Avatar
Better to ask what looks like a stupid question now, than pay for it later
5x114.3 (in millimeters) is the same as 5x4.5 (in inches).
The bolt pattern of the 2 cars is the same, though that may not mean the wheels will fit due to offset, width, etc.
It's almost a given that either set of Infiniti wheels will fit your Maxima, but for the 20" FX wheels, tire shopping may be a bit pricier.
FWIW, some cars have 5x115 bolt patterns (Chrysler 300, among others) and there's always someone managing to cram 5x114.3 wheels on them, with bad long term results. I mention this in case you (or someone else) come across a set of nice looking 5x115s and consider them thinking "what's the difference?"
philpoe is offline
Old 04-26-2006, 11:41 AM
  #210
tkorpus's Avatar
I'm just curious, what are the "bad long term results?"
tkorpus is offline
Old 04-26-2006, 06:56 PM
  #211
jonlawrence's Avatar
Got some G35's on my 00 now
jonlawrence is offline
Old 05-01-2006, 11:11 PM
  #212
sciff5's Avatar
man these things are expensive. I was considering them cause I thought they were cheaper, but the chrome ones I was just looking at sold for more than a grand... friggen silly.. at those prices there are a lot of options.
Where can you get these for cheap?
sciff5 is offline
Old 05-02-2006, 04:06 AM
  #213
Chaser's Avatar
Got mine off E-bay for $450. A little curb rash but for 450 your not going to find them any where else as cheap. Why pay a grand for used rims.
Chaser is offline
Old 05-02-2006, 05:06 AM
  #214
The Ultimate Driving Machine
Park2670's Avatar
Yea I payed $550 for mine, had them fixed and they look good as new
Park2670 is offline
Old 05-02-2006, 06:19 AM
  #215
I30tMikeD's Avatar
In referance to the very first post
If you buy the G35 18's or 19's used, they may come with the automatic tire pressure sensor attached. You CANNOT use this, and probably should replace it with a conventional valve stem
I am looking at a set of the 17x7.5/8 coupe 6-spokes, which supposedly have the tire pressue sensor. Are the 17's with the automatic pressure sensor any different than the 18's or 19's.
-Thanks
I30tMikeD is offline
Old 05-02-2006, 08:23 AM
  #216
I'm needing a caw
Jeff92se's Avatar
Not quite sure why one should remove them. Although they won't work if you don't have the receiver, I don't think it hurts anything to leave them on. I had them left on when I ran the track editions. And if you sell them to another G/Z owner with them on, it can be used as a selling tool. Of course you can have them removed and sell them. They seem to fetch $100-$150 for the set
Originally Posted by irish44j
-If you buy the G35 18's or 19's used, they may come with the automatic tire pressure sensor attached. You CANNOT use this, and probably should replace it with a conventional valve stem
Jeff92se is offline
Old 05-02-2006, 04:17 PM
  #217
swmtam's Avatar
A question for those with 4th gens and G35c 18" wheels.
From the pictures I've seen, most seem to have the fronts pretty flush and the rears recessed a little.
However, my rears are pretty flush, but the fronts stick out a little.
Is there any way to correct this?
Thanks.
swmtam is offline
Old 05-07-2006, 09:49 AM
  #218
The "Other" project
daves04smoke's Avatar
Well guys finally got them on, opinions?
daves04smoke is offline
Old 05-07-2006, 10:03 AM
  #219
02theMax's Avatar
The 19's would've looked better imo, but with a drop those will look great as well.
02theMax is offline
Old 05-08-2006, 04:42 AM
  #220
tripleGmax's Avatar
dont like them on the 6th gen.
tripleGmax is offline
Old 05-09-2006, 08:58 AM
  #221
Dooley's Avatar
Anyone interested in trading 17" G35C wheels (staggered) with me? I have 17x7.5 front and 17x8 rear, want to have a consistant size so I can rotate the tires. Prefer keeping the 8" rears, swapping the 7.5"s to someone for their 8"'s, but I am really willing to do either. PM me if interested...Thanks!
Dooley is offline
Old 05-10-2006, 02:51 PM
  #222
Crooper_Hedder's Avatar
Originally Posted by vq356sp
here is a picture of my maxima with my new g35 coupe 17s by the way just in case anyone cares the drop is on tein h techs.
I'm getting a set of these G35 17x7 wheels for my 4th gen max. I plan to get a set of Proxes for them. What size should I get, 215/50-17 or 225/45-17? These are both within about 1% of my stock 215/55-16 tires.
1010tires.com says that 235's and 245's require minimum 7.5" wheels. So are these sizes out of the question for 7" wheels?
Crooper_Hedder is offline
Old 05-11-2006, 01:24 PM
  #223
JimmyH's Avatar
I did it too...
I got my G35 18" wheels off ebay locally, so I didnt have to pay shipping. I think it was $400. Had some curb rash, that I grinded down and painted. I used the Sterling Mist touch up paint from my car, and it matched almost perfectly.
I got some center caps, I dont know what year, but they have the older style Nissan logo on them. They fit the wheels perfectly. The front wheels had no problem. The back wheels, the tabs from the center cap interfered with the dome end cap on the back axle. So I had to grind down the tabs and that solved it. However, in doing so, the retaining rings wont stay on the caps. They still snapped in place, and havent fallen off yet, but a large bump concerns me.
The front wheels stick out a little, the backs are almost flush. I am not sure yet what that will do to the handling. May improve it since the track width is larger now, but who knows.
I installed Goodyear Eagle GS-D3 235/40/18. I have only driven to work on them so far today, but it is raining here, and I punched it (on really wet pavement) and the car took off almost like on dry pavement, with very little tire spin. And one of the turns I take everyday, when it is wet, I always push a little; these tires held all the way through. I know that has nothing to do with this thread, but I was impressed enough to state it.
I am assuming these wheels are from a Coupe, but they are all the same width and offset. I have read that coupe wheels are staggered. Or maybe it was just the tires.
You definitely feel more of the road with 18s as opposed to 17s. That is a good thing for me though. The maxima chassis is already very communicative compared to most modern coupes and sedans, it is now even more so.
Money well spent I think.
JimmyH is offline
Old 05-13-2006, 12:09 AM
  #224
96blkonblkse's Avatar
i have a 2k2 maxima se and i want to put on the G35C rims the 18x8's i really dont like the look of the stock rims how they are inset and arent flush especially in the back so what size tires and maybe spacer would make it close to flush in the rear and front.
thanks
chris
96blkonblkse is offline
Old 05-13-2006, 03:06 PM
  #225
retired moderator
irish44j's Avatar
wow, I've neglected this thread! Time to answer some questions.
broken studs, wheels flying off while driving, and other things like that. Not bad long term results....they could be bad results in a short time. Not many wheels come in 115mm pattern anyhow, so don't worry about it. Tons of wheels come in 114.3...
The "chrome ones" are OEM replacement rims that companies buy, chrome-dip them, and then jack the price on. There are no chrome ones that actually come on the G35 (which would look gay anyhow). Suggest you look for normal-colored ones.
not to my knowledge....IIRC they are the same.
good point. I didn't say you "have" to remove them, but having them in there would probably required more extensive weights for balancing compared to a simple stem...besides that...
narrower tires, perhaps....
I would go with the 225's I suppose. By the way, IIRC www.edgeracing.com has better prices on the Proxes than 1010, last I looked.
1. read the first post. 235/40/18 will put you closest to stock diameter.
2. spacer in the back would likely cause rubbing on the inner fender lip. I wouldn't suggest them unless you're going to roll the fenders. Besides, the 18x8's are a 30 offset, which is 15mm farther out than your stockers already.
irish44j is offline
Old 05-22-2006, 06:54 AM
  #226
Not for rookies!!
UnMaTcHeD's Avatar
Here are some pics of my car with the 19 inch Rays;
Let me know what you think.
Old 05-23-2006, 07:50 AM
  #227
02theMax's Avatar
The 19's look great!
02theMax is offline
Old 05-29-2006, 02:55 PM
  #228
_ck69_'s Avatar
Did anyone have any issues putting on your rear center caps on the G35 coupe rims? Mine don't seem to fit!
_ck69_ is offline
Old 05-29-2006, 06:21 PM
  #229
02theMax's Avatar
No problems here.
02theMax is offline
Old 05-29-2006, 06:35 PM
  #230
_ck69_'s Avatar
Originally Posted by 02theMax
No problems here.
I guess the 4th gen is different from the 5th gen... hmmm... I'll try to get pics up.
_ck69_ is offline
Old 05-29-2006, 09:29 PM
  #231
_ck69_'s Avatar
Here's a pic of my dilemma. I figured it's the hub/grease cap. Does anyone know if it can be taken off without any repercussions?
_ck69_ is offline
Old 05-30-2006, 12:27 AM
  #232
tkorpus's Avatar
Tap the grease caps in a little with a hammer where the wheele caps are hitting and they should fit fine.
tkorpus is offline
Old 05-30-2006, 03:42 AM
  #233
tripleGmax's Avatar
your problem should be answered in this thread somewhere.
Old 06-01-2006, 05:48 PM
  #234
DRod's Avatar
Here are some pics of my car with the 19 inch Rays; Let me know what you think.
Wheels look great, man. If things go as planned, I should have am '04 Maxima tomorrow. This is EXACTLY what I want to do with mine. Any side shots?
DRod is offline
Old 06-04-2006, 08:26 PM
  #235
DRod's Avatar
BTW, since I'm a newb, I can't do a search...and Yahoo! and Google come up short. Anyone considered or have those 19" split spoke M35/45 wheels on their 6th gen? Threads? Links? Thanks.
DRod is offline
Old 06-08-2006, 01:00 PM
  #236
kramarz99
Did Anyone Try Staggered Wheels On Maxima 2000?
I Want To Mount 18x8.5 On Front And 18x9.5 On The Back, Will It Fit?
And What Offset Would Be The Best?
Old 06-08-2006, 01:04 PM
  #237
I'm needing a caw
Jeff92se's Avatar
You don't have a choice of offsets
Jeff92se is offline
Old 06-08-2006, 01:23 PM
  #238
kramarz99
ok, but will they fit????
what about offset, what should I use?
Old 06-08-2006, 01:31 PM
  #239
dot dot dot ...
NmexMAX's Avatar
Can't you read??
NmexMAX is offline
Old 06-08-2006, 01:50 PM
  #240
kramarz99
sure I can, but my question is : What offset should I use?"
Quick Reply: Wheels/tires Sticky? G35 wheels on maximas
