Widest tire size for 2003 titanium edition wheels
Old 04-26-2005, 10:19 AM
MikeD95SE's Avatar
What is the widest tire size you can fit on a 2003 with the titanium edition wheels... I think they are 7" wide.
Thanks,
Mike
MikeD95SE is offline
Old 04-26-2005, 02:01 PM
350 Detroit Muscle
Ammi's Avatar
235/45/17.
Ammi is offline
Old 04-27-2005, 07:37 AM
MikeD95SE's Avatar
Thank you!
Old 04-28-2005, 09:18 AM
Maximum Performance's Avatar
Originally Posted by Ammi
235/45/17.
what about 245/45/17?
Maximum Performance is offline
Old 04-28-2005, 12:44 PM
350 Detroit Muscle
Ammi's Avatar
that's a no no. too wide for 7" wheel
Ammi is offline
Old 04-28-2005, 01:48 PM
CCS2k1Max's Avatar
I thought there were rubbing issues too.
CCS2k1Max is offline
Old 04-30-2005, 05:27 PM
came4's Avatar
Sorry to ***** your thread bud but could anyone tell me if the titanium rims are a chrome finish or are they painted? I may be able to get a deal but the finished is dorked(sprayed with acid based cleaner I think!!)
came4 is offline
Old 04-30-2005, 08:58 PM
350 Detroit Muscle
Ammi's Avatar
they are not chrome. someone else can describe exactly what color that is
Ammi is offline
Old 04-30-2005, 10:10 PM
ThurzNite's Avatar
235/50-17 is also close diameter to stock 225/50-17.
235/45-17 has more choices. Falken Ziex ZE-512 are popular but not sticky enough for me. Kumho Ecsta Supra 712 if you want something sportier. I like Nitto NT 555 Extreme Performance stiff sidewall. Yokohama AVS ES100 are highly advertised and probably #3 popular affordable autox tire. Kumho ECSTA MX is #1 or #2 popular affordable autox tire.
Jae
ThurzNite is offline
Old 05-02-2005, 12:12 PM
dansmax2003's Avatar
Avon
OK, here is the best solution if you want a wide tire on the stock 17" rims.
Get the AVON M500 or 550AS tire in stock size.
These tires are WIDE, especially the M500. Get them from Tirerack. Stick to stock size. You'll be amazed by the performance, handling and price of these tires. Get them!
dansmax2003 is offline
Old 05-02-2005, 12:33 PM
CCS2k1Max's Avatar
Huh??? My guess is that you work for the Tirerack, Avon or Cooper tires... The section width of the Avons is exactly the same (9.1 inches) as the original crapenzas in 225/50R17 (some would argue that the Kumho ASX should be the way to go since they are 9.2 inches wide). One look at the picture in this thread and you would be hard pressed to prove that those tires are as "WIDE" as you make it sound.
Old 05-03-2005, 01:08 AM
ThurzNite's Avatar
CCS2k1Max: What is the difference of section width and tread width? Why is section width important? Thanx for the info!
Jae
Old 05-03-2005, 06:31 AM
CCS2k1Max's Avatar
The section width (for example a 225 tire) refers to the the overall width of the tire which are the only published numbers. No tire maker publishes the size of the contact patch (including actual tread widths). In the case of the people going for the "widest" 225 tire, it's just for appearance. What's really important is that the contact patch areas of different tire brands will be pretty much the same for equaly sized tires (at the same inflation).
myaeger18
08-24-2015 04:06 PM
Jeffesernia11
08-23-2015 06:09 PM
maximaham
08-20-2015 10:23 AM
twotonezed
08-16-2015 11:41 AM
Quick Reply: Widest tire size for 2003 titanium edition wheels
