4th Gen with 245/45/18?
Old 03-30-2005, 04:04 PM
Zach95SE's Avatar
If I put 245/45/18's on my 4th Gen would it rub bad? I have Murano rims and I got the tires but I don't want them to rub. The car isn't lowered now but will be soon. They are Goodyear Eagle RSA's off of a 6th Gen. If they rub they will be for sale if anyone is interested. Thanks
Zach
Zach95SE is offline
Old 04-01-2005, 07:31 AM
C MAX's Avatar
Zach
i have a set and was wondering the same thing. i have the 2005 max rims 18 in with 245/45/18 on them and im lowered. i got them for cheap from boy who just dropped 20 spinners on his.
C MAX is offline
Old 04-01-2005, 09:16 AM
Zach95SE's Avatar
Yeah I have Murano rims. I guess I'll just go one mounted and see how it is unless someone else with experience says something
Zach95SE is offline
Old 04-01-2005, 10:58 AM
C MAX's Avatar
well if it doesnt rain this weekend i will put two on the front to see how they ride. so either you post or i will the results. but i think if your not dropped it would fit. my brother has a 96 stock height and he wants them, if they dont fit on mine so we will try both.
C MAX is offline
Old 04-03-2005, 09:33 AM
Doc
Doc's Avatar
Fellas, keep this thread going and make sure to post your experiences. The reason I ask this is I have a set of Muranos coming and am wondering whether to put 235/40 or 235/45's on them. I'm thinking 245's may be too wide, but keep me posted. GL guys.
Doc is offline
Old 05-03-2005, 06:34 PM
Chocolate_Boi_1Der
Cant_Get_Ryte's Avatar
anyone yet?
Cant_Get_Ryte is offline
Old 05-03-2005, 06:50 PM
sean05's Avatar
yeap mine rub. It rubbed a hole in the panel right behind the wheel. I took it off and now it is fine. Nothing major to me. But if i would do it againg i would get 235/35s.
sean05 is offline
Old 05-03-2005, 07:53 PM
Lawtown's Avatar
Now is this lowered or stock height? And if lowered, how low and what springs?
Lawtown is offline
Old 05-04-2005, 03:34 AM
C MAX's Avatar
mine only rubbed when i made a full turn, but still rubbed. im lowered with eibachs i think its a 1 1/4 drop.
C MAX is offline
Old 05-04-2005, 09:12 AM
sean05's Avatar
im lowered with sprint springs. rubbed a good bit.
sean05 is offline
Old 05-04-2005, 11:03 AM
2060lbs and falling...
Broaner's Avatar
245/45 is much taller than the stock OD and will hurt acceleration. Its not the width that matters. You can never have too much rubber on the road in these cars. They have tons of space for tire. Andy from Top Element has run 255's on 4th gens. Its the aspect ratio that matters and effects the OD. The OD effects the gearing. The gearing effects acceleration.
The OD's of various sizes are as follows.
245/45=26.82"
245/40=25.84"
205/65=25.66"(Stock)
That means the OD will be well over an inch larger. That will be horrible for performance but if that doesn't matter to you go for it.
Broaner is offline
MAXSE5SPD
09-17-2022 04:00 AM
VQ'ed
Forced Induction
02-29-2016 08:05 AM
imported_Nismo_max
09-21-2015 07:24 PM
Violator
09-09-2015 10:14 AM
Lowered_a33
09-01-2015 07:49 PM
Quick Reply: 4th Gen with 245/45/18?
