correct tire size for my max...
Old 08-05-2004, 03:22 PM
exardus's Avatar
hey guys, i have a 97 maxima SE i believe with 16 inch tires. Right now i have 205/55/R16 rubber on them. I want to get some new tires, and i was wondering what's the stock tire size that came with the car. Thanks in advance.
exardus is offline
Old 08-05-2004, 03:35 PM
Frank Fontaine's Avatar
97 was 215/55-HR16, probably came with RS-A or Proxes. I believe that the GLE or GXE had 205/65-15's, but don't quote me, check out tirerack.com. If you've got 15's in a 205, you probably have the right size--maybe you have a GLE where someone added a rear spoiler?
Frank Fontaine is offline
Old 08-05-2004, 03:39 PM
Minister of Silly Walks
mzmtg's Avatar
Originally Posted by Frank Fontaine
blah blah blah 215/55-HR16 blah blah blah blah blah blah blah blah
Fixed!
mzmtg is offline
Old 08-06-2004, 07:44 AM
exardus's Avatar
i got some bridgestone potenzas re92 very cheap, but the thing is that they're 205/50/R16. besides the fact that the speedo will be lying by 4%, is there any other reason why it would be bad to put them on?
exardus is offline
Old 08-06-2004, 03:59 PM
mzmtg's Avatar
They might look a little small, but other than the speedo error, there's no real reason not to run them.
mzmtg is offline
Old 08-18-2004, 04:26 PM
pigburger's Avatar
I'd go with 225/55/16s. There's a pretty good selection of them in all sorts of styles and they fill up the wheel well nicely. I ran the BF Goodrich KDWS without complaints, but also was totally impressed with with the Pirelli SuperSport, except in inclement weather.
pigburger is offline
Old 08-19-2004, 03:37 PM
exardus's Avatar
ok thanks alot for your replys'.
exardus is offline
Old 08-27-2004, 10:08 AM
exardus's Avatar
if smaller tires effect the speedometer readings, would they also effect the odometer? and in which way?
exardus is offline
Old 08-27-2004, 11:53 AM
mzmtg's Avatar
Yes, in the same way.
mzmtg is offline
VQ'ed
Forced Induction
02-29-2016 08:05 AM
RIPTIDER
Wheels/Tires
01-31-2016 07:39 AM
mikeymouse1995
09-18-2015 06:42 AM
Serotta33
09-17-2015 12:14 PM
meccanj98
09-16-2015 07:23 AM
Quick Reply: correct tire size for my max...
