265/35/18 on 18x9.5
Old 03-26-2004, 06:51 AM
BIGMAX19's Avatar
265/35/18 on 18x9.5
can you fit 265/35/18 on the rear of a max with 18x9.5????
4th generation max
BIGMAX19 is offline
Old 03-26-2004, 07:51 AM
BIGMAX19's Avatar
Originally Posted by slammed95
Yes, as long as the wheels have the correct offset. Better off with a 255/40/18, the slight increase in diamter doesn't matter for the back, and the car will look lower.
i'm lookin for a little more support from potholes....255/40 is good enough you think????
BIGMAX19 is offline
Old 03-26-2004, 08:10 AM
BIGMAX19's Avatar
i'm looking at 18x8.5 fr and 18x9.5 back...and i just called and they told me to go with a 35 offset with a 40 offset i will need spacers...does that sound right???
BIGMAX19 is offline
Old 03-26-2004, 08:55 AM
BIGMAX19's Avatar
so which one should i go with...they have both 35mm and 40mm offsets....
BIGMAX19 is offline
Old 03-26-2004, 08:10 PM
josh95se's Avatar
Someone else here has 19x9.5's with a 42 offset and says they fit well...if you go with 40 they will only stick out 2mm more so should probably be ok. What wheels are you looking at?
josh95se is offline
Old 03-27-2004, 12:04 AM
BIGMAX19's Avatar
i'm looking at getting these wheels here...
http://www.wheelmax.com/Wheels/AZA/AZA.htm
the z1.....
BIGMAX19 is offline
Old 03-27-2004, 12:14 AM
josh95se's Avatar
nice wheels
josh95se is offline
AzNx2k2xSEXima
10-10-2011 07:13 PM
AzNx2k2xSEXima
Wheels/Tires
09-07-2011 04:11 AM
BIGMAX19
Tires and Wheels
03-26-2004 12:30 PM
hlh0501
10-03-2002 03:23 PM
Quick Reply: 265/35/18 on 18x9.5
