Just picked up this wideband. Need tuning advice
Old 03-13-2018, 01:24 AM
PhalC1's Avatar
https://www.maperformance.com/products/plx-devices-sm-afr-dm-6-52mm-wideband-oxygen-sensor-package
I need some advice on tuning. I've got everything ready for my turbo setup coming and then I'll have a manifold fabbed up.
I've got an OBDII to usb, I just don't know what program would be best to use. Utec, nisprog/romraider, haltech, etc etc
I know that it's dangerous to tune if you don't know what you're doing, but I've always wanted to get in to it and I've got a Guinea pig car to test on and I'll be doing my due diligence in making sure I research as much as I can. Just need some guidance
PhalC1 is offline
Old 03-13-2018, 08:11 AM
Nistune FTW!!
ChrisMan287 is offline
Old 03-15-2018, 07:13 PM
SR20Power's Avatar
Whatever you use, make sure you have something that can give your recorded A/F ratio across the RMP band so you know where to adjust the fuel. And depending on the program you have, you can adjust timing, injectors blah blah.. GL. Post pictures!
SR20Power is offline
Dub Jones
09-15-2018 09:48 PM
shadyonedeath
10-16-2009 08:37 PM
My-Body-Is-Ready
04-15-2007 05:46 PM
4x4Max
01-22-2007 12:51 PM
jonniewaka
12-13-2004 05:25 AM
Quick Reply: Just picked up this wideband. Need tuning advice
