questions about nistune
Old 05-29-2016, 08:43 AM
aw11power's Avatar
ok guys, i meed some nistune info, first off; do i need a tuners licence? or can i use other software for tuning like live edit? like if i buy and install a board, can i tune it with other software or does it HAVE to be the nistune software. reason i ask is i cant afford nistune outright right now. but in theory i could park the car for a bit, sell my apexi neo and 86 300zx turbo ECM and buy a nistune board that i could install on my 88 maxima ECM. i think the maxima computer would be better as its the newer style with the 16 bit processor. help me out here guys, anyone have some helpful info on nistune? i actually just turned my boost back down to 10psi because at 14psi, my air flow meter and injectors were maxing out. i need full ECM control to meet the power potential of my turbo.
aw11power is offline
Old 05-29-2016, 01:06 PM
akurtzer57's Avatar
You need the license to be able to tune the car. I know a dealer in Denver Colorado he mainly does all type 1 boards. Mostly z31. If you send him your ecu and believe its around 360-380 with license installed and back to you.
akurtzer57 is offline
Old 05-29-2016, 01:24 PM
aw11power's Avatar
ok, thats what i thought but wasnt sure. i need to know if i can use it on the 88 maxima ECU. if so, selling my 300zx turbo ECU and my apexi neo should almost get me enough scratch for it.
Old 05-29-2016, 06:45 PM
akurtzer57's Avatar
Looks like you need use a z31 ecu. It can be any z31 ecu just be sure to match the injector drivers to you impedance ecu. z31 had high and low impedance. I would recommend using a 87+ turbo ecu
http://nistune.com/equipment-products.php
Old 06-04-2016, 06:27 PM
aw11power's Avatar
i got in touch with Matt at nistune and he did clear some stuff for me. he recomended a late z31 board just as you did. but he also said that he was pretty confident that i could install it in the maxima ecu since its the same board, just set up for the zorconia 02 sensor and ficd type idle controls.
Old 06-11-2016, 05:16 AM
2nd Gen Boostinator
Big_E-Dog's Avatar
naaaah you can do it on a maxima ecu. ive done it. bout the same
Big_E-Dog is offline
valerit1
05-19-2016 04:13 PM
Stagnet04
03-19-2016 09:44 AM
crewchief264
02-22-2016 05:43 PM
066spd
02-19-2016 09:29 AM
TonyJr
Forced Induction
02-19-2016 04:50 AM
Quick Reply: questions about nistune
