high torque capacity clutches...
Old 05-25-2016, 07:17 PM
aw11power's Avatar
so im looking for advice on a clutch upgrade. ive found that 85-99 manuals all have interchangable clutch/pressure plate assemblies. what have you guys had good luck with?
aw11power is offline
Old 05-26-2016, 07:14 PM
akurtzer57's Avatar
I ran southbend with good results and now on a spec but haven't drove with the spec yet. I actually used a z31 clutch this time around just due to it laying on the shelf in the box.
akurtzer57 is offline
Old 05-27-2016, 05:11 AM
aw11power's Avatar
is the Z31 clutch a direct fit? 240mm or 250mm? my friend at orielly could warranty my current lifetime clutch and ai could upgrade to a Z31 clutch for almost nothing out of pocket. i know the turbo clutches are good for 340lbs of torque, i dont know about the NA clutches. any help would be greatly appreciated. even tho my car is an 88, im using a 91 flywheel, clutch and pressure plate. so whatever fit yours would also fit mine.
Old 05-28-2016, 07:53 PM
Get Off My Lawn
Chris Gregg's Avatar
I had a Spec stage III IN MY '89 Turbo. Absolutely perfect, no issues or complaints.
Chris Gregg is offline
Old 05-28-2016, 09:13 PM
SLOW
Nealoc187's Avatar
how high of torque are we talking about here?
Nealoc187 is offline
Old 05-29-2016, 08:28 AM
aw11power's Avatar
ill need something thats good for over 350lbs of torque.
Old 05-29-2016, 06:47 PM
akurtzer57's Avatar
Was pretty much direct swap. I believe I had to just slightly enlarge the alignment pin. Wouldn't quite slip on my flywheel with paint etc. Did use the maxima throw out bearing.
FanaticMadMax
05-23-2016 03:08 PM
BETO6700
05-20-2016 12:25 PM
District
05-09-2016 09:37 AM
District
05-05-2016 09:49 PM
Vdub328
04-29-2016 06:35 AM
Quick Reply: high torque capacity clutches...
