sc or na
Old 05-18-2016, 06:06 AM
Maximeltman's Avatar
sc or na
i got a 3.5 swap but it has hr cams/ hr pistons/hr springs double-shimmed and hi rev oil pump.. so its not a stock 3.5, also has ARP bolts and studs all around. what can I boost safely as far as psi because i think the compression is a little more than stock 3.5?
Maximeltman is offline
Old 09-01-2016, 07:23 PM
Anyone shed some light here?
Old 09-05-2016, 12:18 PM
aw11power's Avatar
psi is really relative. are you pretty set on a supercharger? and whats your actual compression ratio? a lot of people seem to run 7 or so with a supercharger on stock motors. so thats honestly a hard question to answer.
aw11power is offline
Old 09-06-2016, 08:33 AM
Crusher103's Avatar
Stock DE rods plus high compression with boost is not a good idea. I wouldn't added boost to your motor just stay NA. If you do want to boost the HR pistons would have to go, and while your in there you might as well toss in some eagle rods then boost. Those are my first thoughts.
Your motor definitely would not be turbo friendly you might be able to get away with a supercharger but i wouldn't push it. your compression currently should be in the 11.x:1 range a boarder line 300whp NA motor, if healthy and given proper tuning.
So in all honesty i would just enjoy your car as is, you have a nice setup. Work on other things, suspension, brakes, aesthetics. Boost is headaches. i can understand wanting it, its fun but i would suggest getting a second car if you want to boost, there will be some downtime involved. Almost every one i know on here with a boosted car has a second car/DD including myself. But if your buying a second car move to a better platform and keep the maxima as a DD that is the best solution.
Crusher103 is offline
Old 09-06-2016, 08:36 AM
Crusher103's Avatar
On a Supercharger its understandable to talk PSI, 4th/5th gens only run 2 blowers, the Vortech V1 and V2 and they are very similar and size and output.
Old 09-06-2016, 03:41 PM
The Crazy Azz Cracka
choray911's Avatar
Good luck on even finding a SC.
They are hard to *** by these days.
choray911 is offline
Old 09-06-2016, 08:02 PM
that's because I'm hoarding them all.....
The Wizard is offline
Old 09-07-2016, 06:08 AM
choray911's Avatar
oh really? how many you gotz?
Old 09-07-2016, 06:15 AM
choray911's Avatar
Old 09-07-2016, 09:37 PM
okAY then! Thanks Crusher.
Anyone want a sc? haha
Old 09-08-2016, 12:41 AM
I haz 6 complete kitz (4 installed, 2 uninstalled)
Old 09-08-2016, 07:36 AM
tech2000's Avatar
Sell me one bro
tech2000 is offline
Old 09-09-2016, 08:03 AM
choray911's Avatar
For reallz, you wanna unload one?
Old 09-09-2016, 09:31 PM
Crusher103's Avatar
My irrational hatred of Wizard continues to grow....
Old 10-20-2016, 01:14 PM
I like Maximas
vipervadim's Avatar
I have 3 kits..
When I offered to sell one, nobody put up any serious $$$, and I'm not about to sell mine for under $2K.. demand and supply..
Maxima people = cheap, completely unreliable, and make me say "SHOW ME THE MONEY" first before anything happens. No need to get defensive, just stating facts for the record.
vipervadim is offline
Old 10-20-2016, 02:44 PM
Bad *** Newb
Child_uv_KoRn's Avatar
Oh, no, not irrational. It's contagious. I feel the hatred, now.
Child_uv_KoRn is offline
Old 10-20-2016, 04:49 PM
Old 10-20-2016, 05:30 PM
Originally Posted by vipervadim
I have 3 kits..
Old 10-05-2017, 03:41 AM
CHEF KOCH's Avatar
This is the most important comment on the forum. Never boost to early, sort your life out first, save ya money and build a street drag machine when you have a garage/savings etc.
NA VQ35 will still go hard and will save you an insane amount of time and money in the long run
CHEF KOCH is offline
Old 10-05-2017, 09:03 AM
^You're only a year late to the party.
Old 10-05-2017, 08:25 PM
CHEF KOCH's Avatar
I know... I wish I had joined a long time ago after spending most of the night reading through threads
AT978
25
07-20-2016 07:40 AM
SEDaveMax
05-26-2016 03:55 PM
camako
05-15-2016 03:43 AM
Blassmasta
05-10-2016 12:29 PM
GDMills
04-24-2016 10:23 PM
Quick Reply: sc or na
