Emanage Ultimate question....Red flashing
Old 07-10-2015, 06:31 PM
matty's Avatar
Okay my car has been sitting because I have it listed for sale
I took it for a ride today and noticed that the left light on the EMU is flashing red. I did some research and many Greddy guys say the firmware needs to be reflashed. Anyone do this ? I plugged it into my laptop and it's showing a bunch of errors. Anyway to competely reset the Emanage and start fresh ?
Matt
matty is offline
Old 07-13-2015, 08:52 PM
matty's Avatar
No one ?
matty is offline
Old 07-14-2015, 08:31 AM
MoncefA33's Avatar
Do you have screenshots of the errors it's giving you?
I would connect the laptop, click Communication, and click on Main Unit Update. It'll reboot the EMU and reflash the firmware to it.
MoncefA33 is offline
Old 08-11-2015, 04:56 PM
matty's Avatar
This is what I get when I click communications and go to main unit update
Here are my errors. Checked the connections on those and they are tight
Here is my version. Prob really old
matty is offline
Old 08-13-2015, 05:06 AM
MoncefA33's Avatar
I don't see anything wrong with the firmware/software, looks like the versions both match.
Check your harness for wiring issues on the ignition wiring, for cylinders 1 and 2.
Old 08-13-2015, 05:09 AM
matty's Avatar
All the cylinder ing wires are tight soldered.
I guess my next recourse is taking the unit out and sending it out to Greddy
I did read in anther forum that on some early model Ultimates, the case rubbed against the board and caused Ing chips to get dislodged
Matt
matty is offline
Old 08-13-2015, 12:26 PM
What hardware version do you have? I believe anything older than E (A,B,C,D) had the loose ignition chip issue.
The Wizard is offline
Old 08-15-2015, 08:55 AM
matty's Avatar
Is this soemthing I can fix or needs to be sent back to Greddy ? It's drivable but geeks once once it's warmed up
Matt
matty is offline
Old 08-15-2015, 02:04 PM
matty's Avatar
Unplugged it today, took it apart and put it all back together and no more red light. Drove it a bit. Red light back one. Now showing ing2 and Ing 3 error
Here's the one I have Only markings I can find
matty is offline
Old 08-15-2015, 02:09 PM
Fakie J Farkerton's Avatar
The markings you would look for are on the board itself, inside the case.
Fakie J Farkerton is offline
Old 08-15-2015, 03:00 PM
matty's Avatar
Looks like mine is a C.
Would the loose ignition chip issue make the car run funky ? Can barely get the car to idle. Idles and just dies
Matt
matty is offline
Old 08-15-2015, 03:34 PM
Matt
Hmmm...not sure. Usually the ignition chip issue prevents the car from even starting. I'd call Greddy to be sure.
Old 08-20-2015, 06:43 PM
matty's Avatar
Question: Jumper 8/Ignition output I have set for 5V. Does it need to be 12V ? According to Greddy it needs to be set to 2-3 which is 12V for the ignition output
matty is offline
Old 08-20-2015, 09:43 PM
Follow Dandy's writeup on the jumpers. It's supposed to be set to 1-2 for 5V.
knight_yyz
11-06-2015 02:34 PM
dshinn
09-26-2015 08:07 PM
Quick Reply: Emanage Ultimate question....Red flashing
