Sparkplugs on a Boosted Maxima
Im in the process of tuning my boosted Maxima and I was wondering what sparkplugs would you guys recommended for my application. I know a few guys who have been boosted for a while, and Im sure y'all have y'alls preferences. (OEM specifications, 2 step colder, etc) Any suggestions would be greatly appreciated.
NGK Coppers, 1 step colder.
Gap will be determined on your boost levels. You alwasy want to run the biggest gap possible without experiencing blow out.
Im gapped @.028 but when i was making 10lbs of boost I was gapped @ .034
Me too.
Me three.
Exactly. Bold added for emphasis.
Me three.
How do you determine how much you need to gap them. Sorry for all the noob questions. I've gone once into boost and it reached 10-11 lbs.
Start with .034 and see how that does, Im sure it will be pretty good. If so, try opening them up just a bit untill you feel the car hesitating a little in the upper rpms when going WOT, when you do back the gap down a bit.
Found it. Good stuff peeps. Thanks a lot! Car should be up on the dyno for a tune in the next few weeks. Here's the link in case anyone stumbles upon my thread looking for the same answer.
http://forums.maxima.org/supercharge...elts-etcc.html
Go to NAPA to get the copper plugs, you can get them as cheap as $1.20 a piece and up to $1.99 a piece change them out every 20k.
One step colder copper plugs:
NGK # BKR6E-11
Nissan # 22401 - 50Y06
two step colder
NGK # BKR7E-11
The -11 part of the NGK number is multiplied by .004" to get the gap size for an engine producing stock hp. This would make the stock gap 0.044". Most people with SC's and such are running 0.034" - 0.038" in order to further reduce tendency for detonation.
NGK # BKR6E-11
two step colder
NGK # BKR7E-11
I'll probably run somewhere between 10-12 lbs, but my intercooler pipe is smaller(diameter-wise).
Eh... 6 bucks multiple times will add up eventually.. I'll save when i can.. And i was just making sure cuz i was thinking to stock up... Thanks though.. I'll just go grab em before they go up lol
Finkle
09-27-2015 09:53 PM
MaximaDrvr
08-19-2015 08:20 PM
