Go Back   Maxima Forums > Advanced Performance > Supercharged/Turbocharged
Sign in using an external account
Register Forgot Password?
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 02-02-2012, 05:10 PM   #1
Boosted Panda
Flava_24/7's Avatar
Points: 15,825, Level: 80
Points: 15,825, Level: 80 Points: 15,825, Level: 80 Points: 15,825, Level: 80
Activity: 2.8%
Activity: 2.8% Activity: 2.8% Activity: 2.8%
Possible part out....
Well, my car has ran into some issues and I discovered a very troubling cause today which is now got me seriously thinking about what to do next.
Now I just had this motor built for me by a local mechanic that was refered to me by another individual and looks like I may have got shafted on the build.
The motor has only been in the car for a little over three months and just recently I ran into an issue with it driving home from work one day.
Now since its been running I really havent gotten on it at all. The hardest it was pushed was when I got it tuned. Other then that Ive just been driving it back and forth from work, and not everyday at that.
So on the way home from work one day the car begun to hesitate and jerk when i gave it gas, it then eventually just stalled out and I could not get it to start up again so I had it towed home.
Once I got it home I tried to start it up again with no luck, I eventually killed the starter. When cranking it I could smell a crap load of fuel, so I pulled the plugs and they were soaked, swapped them out and replaced the starter and after a lot of cranking it did start up but ran really rough and was smoking really bad, also it was spitting out fuel from the exhaust tip.
So the car sat for a while cause I just didnt have any time to really work on it, today I had off so I removed the injectors and inspected their O rings and found two that needed the smaller O rings replaced so I ended up replacing all six small and large O rings. With that done I thought awesome, and I figured that would correct the problem and reassembled everything, changed the oil and went to crank the car again.
Now after a lot of cranking the car did start up once again, but it still ran very rough though but I didnt smell all the fuel anymore so I figured I would just keep it running long enough to burn off all the excess fuel. It never smoothed out so I left off the gas and it died off.
So once it stalled out I walked to the back of the car to see how much fuel was spit out through the muffler and still saw quite a trail, but also found something else that I wasnt expecting. I found a few pieces of metal laying on the ground in the puddle of fuel and upon closer inspection the pieces of metal turned out to be the remains of a valve, exhaust valve Im assuming.
I never wouldve thought that it couldve made it all the way down and out the muffler but it did.
So, at this point Im just not sure what to do with this car. I just dropped a good chunk of change for the rebuild, which was supposed to be a complete rebuild with everything new and now this.
I will be contacting the builder tomorrow but Im sure he will deny that the failure was due to his assembly, so Im sure I will need to take him to court. Having him do the repair or rebuil is out of the question. All I want from him is my money back.
If I win, I may put that money back into having either the motor repaired, another rebuild or just possibly may cut my losses and do a part out and move onto something else. I really hate to let the car go just like that, more so since I didnt even really get to enjoy the newly built motor. I really wouldve liked to beat on it some and truly enjoy the new power it was making. If I do get rid of it, another option would be to buy another cheap VQ, drop it in and sell it as a whole, although Im sure I wont get much for the car.
Now from what I gather, there are a few things that couldve caused the failure, cheap parts, incorrect install but does anyone think that using the rev up cams and cam adapter have any role in this as well? Any other thoughts on what couldve been the causing factor?
Its crazy cause the car has been running really well up to this point.
Here are pics of the valve I found....
This is where I found it sitting....
Flava_24/7 is offline   Reply With Quote
Old 02-02-2012, 05:43 PM   #2
Silver Tooth S2K 9k FTMFW
95 maxima se's Avatar
Points: 8,001, Level: 60
Points: 8,001, Level: 60 Points: 8,001, Level: 60 Points: 8,001, Level: 60
Activity: 2.4%
Activity: 2.4% Activity: 2.4% Activity: 2.4%
Send a message via MSN to 95 maxima se
damn ralph!!! this blows bro best of luck, hope he pays you back
__________________
3/18/11 5.5gen maxima! soon to be sold
Next:
AP1 S2K
95 maxima se is offline   Reply With Quote
Old 02-02-2012, 06:08 PM   #3
The Retro Guy
Points: 12,603, Level: 73
Points: 12,603, Level: 73 Points: 12,603, Level: 73 Points: 12,603, Level: 73
Activity: 95.7%
Activity: 95.7% Activity: 95.7% Activity: 95.7%
That's insane. At least your license plate has meaning now.
I doubt it was the cams/adapters.
ChrisMan287 is offline   Reply With Quote
Old 02-02-2012, 06:17 PM   #4
Boosted Panda
Flava_24/7's Avatar
Activity: 2.8%
My plate always did have meaning, a SCed vehicle is commonly refered to as being blown. But thanks for your insight.
__________________
The original Panda Maxima
Old 02-02-2012, 06:25 PM   #5
McSteve's Avatar
Points: 5,709, Level: 48
Points: 5,709, Level: 48 Points: 5,709, Level: 48 Points: 5,709, Level: 48
Activity: 10.0%
Activity: 10.0% Activity: 10.0% Activity: 10.0%
has to be timing right? i don't think i've ever heard of a cracked valve on a vq before.
__________________
MODS:
BC Coilovers | Stillen FSTB | Progress Rear Swaybar | ES BUSHINGS | Subframe Collars | 10mm Front/ 25mm Rear Eibach Spacers | Unorthodox UDP | CC OBX Headers | NWP Intake Spacers | Cattman 3" Catback + Test Pipe | 3.5" WAI w/ LR MAF | PFTB | NWP Engine Torque Link | Shinjinduo Grounding Kit | 300ZX BBK | Ionic Dynamics Bodykit |Retrofitted TSX Projectors | Foglight HIDs |License Plate LEDs | Blacked out grills | Pioneer Avic-D3 | Interior LEDs | 5 SPD SWAP
BUY MY MISCELLANEOUS STUFF!!! CLICK HERE
McSteve is online now   Reply With Quote
Old 02-02-2012, 06:34 PM   #6
Boosted Panda
Flava_24/7's Avatar
Activity: 2.8%
Quote:
That's what I was thinking, either that or the lash was set incorrectly? I've never heard of this happening in a VQ either, nor have I ever heard of a valve making its way all the way through the exhaust.
__________________
Old 02-02-2012, 06:36 PM   #7
Points: 18,080, Level: 85
Points: 18,080, Level: 85 Points: 18,080, Level: 85 Points: 18,080, Level: 85
Activity: 100.0%
Activity: 100.0% Activity: 100.0% Activity: 100.0%
Crusher103
Send a message via AIM to Crusher103
wow, damn man that ****en sucks.
If it were rev up cams and their adapters i would have found that out a long time ago. I beat, i mean i BEAT on my car before i took it down for its turbo build, and this was untuned. Never give me any trouble. I think the timing was most likely off or the cam adapter broke or was installed incorrectly. I have had to test spin my motor to make sure the cam adapter and was seated correctly and spinning. I had a bizarre incident where the cam didnt spin with the rest of the motor and i had to take it apart and reinstall.
That valve definitely got struck by the piston. Which would lead me to believe the exhuast cam adapter was not installed correctly.
__________________
96 Black I30t A.K.A Big Black
YES my car has more mods than yours. And NO its not reliable.
Quote:
Originally Posted by MrGone View Post
.......he went to cut down some trees and burn them to counteract the jeffafafa you brought to the thread
Quote:
Originally Posted by T_Behr904 View Post
We're still trying to get a BBW........
Quote:
Originally Posted by DrunkieTheBear View Post
Anytime I need to feel the love of men, I come on here.
Crusher103 is online now   Reply With Quote
Old 02-02-2012, 06:43 PM   #8
Kevlo for President
Kevlo911's Avatar
Points: 36,451, Level: 100
Points: 36,451, Level: 100 Points: 36,451, Level: 100 Points: 36,451, Level: 100
Activity: 98.1%
Activity: 98.1% Activity: 98.1% Activity: 98.1%
Def was not assembled correctly. Sucks buddy. Hope you can get your money back and at least just run this thing with a DEK
__________________
97 Pearl White Max GLE
Kevlo911 is offline   Reply With Quote
Old 02-02-2012, 07:03 PM   #9
Points: 7,223, Level: 56
Points: 7,223, Level: 56 Points: 7,223, Level: 56 Points: 7,223, Level: 56
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
Damn R. Def sucks big time. Hopefully he will give some $$$ because I don't want to hear possible "Panda" part out talk!!!
__________________
1998 VQ SE Maxima(MAXINE)
19" A34 Nismo's/HIRO's.Brembo Rotors.GR2's S-Techs.Optima Yellow.MEVI.StillenY/OBX Catback.VB Auto.Stillen Lip/Ionic CF Skirts & Rears.Paradox LED Mirrors.Window Spoiler.Type X Spoiler.AutoMeter Gauges.Pioneer system.8K HID's/9K fogs
**ready to swap 3.5 in**
1991 VG Maxima GXE(PEARLE)
9K HID's.Fogs.Optima Yellow.Pioneer w/ L7's.Stillen Kit.2K SE Rims.Tokico/Eibach.Warpspeed Y/Hi-Flow & Custom Catback.Autometer Gauges
***R.I.P. BISHNU - Always SecondtoNone***
AllMaxxedOut is offline   Reply With Quote
Old 02-02-2012, 07:07 PM   #10
Points: 6,670, Level: 53
Points: 6,670, Level: 53 Points: 6,670, Level: 53 Points: 6,670, Level: 53
Activity: 5.0%
Activity: 5.0% Activity: 5.0% Activity: 5.0%
Oh no! Fix it, make them fix it.
__________________
SHIFT_Supercharged
Quickywd01 is offline   Reply With Quote
Old 02-02-2012, 07:14 PM   #11
Boosted Panda
Flava_24/7's Avatar
Activity: 2.8%
Quote:
I honestly doubt he will want to, I know hes going to say it wasnt due to the assembly and that I must have been beating on the car so Im sure I will have to do a civil suit.
Sucks, Im tired of getting burned. My original motor had a blown head gasket so I picked up a cheap motor from an org memebr to run while I rebuilt the other motor but the motor I bought ended up having a spun bearing.Soooo I opted to do this build sooner then I wanted and now just 3 months later Im back to having a dead motor.
Thats good to hear, i didnt want to know that it was due to the cams/adapters and not the assembly.
Quote:
Thanks man, Im hoping so too. A real close friend of mine has offered to rebuild it if I choose he also suggested throwing in another good used motor. IDK though. Im a bit torn at the moment.
Quote:
That would be my worst case scenerio. If anything Id try to buy a vey cheap motor, drop it in as is and just sell the car as a whole if I did decide not to rebuild it.
Hard though, Ive had this car since 97 and wouldve loved to build a nice beast to play with until I was tired of it.
__________________
Old 02-02-2012, 07:18 PM   #12
Boosted Panda
Flava_24/7's Avatar
Activity: 2.8%
Quote:
Thats not even an option for me, all I want from him is my cash back.
I should have known something liek this was going to happen. They guy orignally told me he could pull, rebuild and install the motor in two weeks, it took 3 months! Then when he called and said it was ready I got there, started it up and the rear main was leasking so he had to fix that. The next day I went to pick it up and drove it home, as soon as I pulled into my driveway the pulley on the power steering pump literally fell off and with it wobbling around it detroyed the splined shaft so I had to take it back once again to fix it.
Then, one week later the rear valve cover began leaking like crazy cause he didnt silicone the inner corners so he had to fix that also and now this.
Its been a total nightmare.
__________________
Old 02-02-2012, 07:32 PM   #13
I'm a Focker
Conrad283's Avatar
Points: 60,140, Level: 100
Points: 60,140, Level: 100 Points: 60,140, Level: 100 Points: 60,140, Level: 100
Activity: 99.6%
Activity: 99.6% Activity: 99.6% Activity: 99.6%
Send a message via AIM to Conrad283
Sucks man ... Sorry to hear about this. Always liked your car
__________________
Quote:
Originally Posted by NCSU_MAX View Post
8.) Theres a show in the desert called "Race Wars". We'll see how you do. Then we'll talk.
has to still be engaged, was pondering selling the prix
Conrad283 is offline   Reply With Quote
Old 02-02-2012, 08:44 PM   #14
Turbo 3.5
Points: 15,647, Level: 80
Points: 15,647, Level: 80 Points: 15,647, Level: 80 Points: 15,647, Level: 80
Activity: 7.8%
Activity: 7.8% Activity: 7.8% Activity: 7.8%
to me it sounds like the dowel pin failed and the cam and gear went out of alingment. Now wheter it was from the cam adapter or if the pin in the cam was just left out I can't tell.
Cam adapters have failed in the pass but again I can not confirm if it was from the cam bolt not being torqued correctly or the pin breaking.
One I can said is not sure if you got the adapters directly from stepenmax or 2nd hand but there are some copies floating around
only other thing I can think of is the wrist pin broken allowing the piston to hit the valve
__________________
My Cardomain _ _Maxima runs 13.4@109
Nitrous PB: 13.4@110mph
All Motor PB: 14.0@99mph
3280lb with driver, full trim, rims, spare, jack, fluids, etc & notorized proof
t6378tp is offline   Reply With Quote
Old 02-02-2012, 08:51 PM   #15
Turbo 3.5
Activity: 7.8%
btw this really sucks, I've there been there and know the angry. Walk away for a few days and then make up your, I would just get a stock motor from the yard hopefully see it run before its pulled and put your cams in it and enjoy
__________________
Old 02-02-2012, 09:04 PM   #16
Points: 11,561, Level: 70
Points: 11,561, Level: 70 Points: 11,561, Level: 70 Points: 11,561, Level: 70
Activity: 24.9%
Activity: 24.9% Activity: 24.9% Activity: 24.9%
Send a message via AIM to wirelessdude04 Send a message via Yahoo to wirelessdude04
Wow!!!
wirelessdude04 is offline   Reply With Quote
Old 02-02-2012, 09:33 PM   #17
KH3 by popular demand
maxgtr2000's Avatar
Points: 9,173, Level: 64
Points: 9,173, Level: 64 Points: 9,173, Level: 64 Points: 9,173, Level: 64
Activity: 4.9%
Activity: 4.9% Activity: 4.9% Activity: 4.9%
maxgtr2000
Send a message via Yahoo to maxgtr2000
The thing is trying to prove that it wasn't a freak accident and that the mechanic is liable. I would give the car a new heart because you would have to let it go for way less than you are expecting, better for you to drive and enjoy it because it has more value to you.
__________________
My VQ30DET
There can be no peace until you possess the Prince of Peace.
maxgtr2000 is offline   Reply With Quote
Old 02-02-2012, 09:56 PM   #18
Points: 5,857, Level: 49
Points: 5,857, Level: 49 Points: 5,857, Level: 49 Points: 5,857, Level: 49
Activity: 0%
Send a message via Yahoo to olivas
Wow man that really sucks hope everything work out for you man, got to say it would if you sell your max one of the prettiest car's on the org.. Good luck with everything and keep us posted..
__________________
________________
96GLE Stillen Intake/Stillen Cat Back/Alpine/Eibach Springs/18x8.5 Gram Lights 57s-pros/NRG CF hood/Stillen Areo kit
olivas is offline   Reply With Quote
Old 02-02-2012, 10:43 PM   #19
Points: 2,937, Level: 33
Points: 2,937, Level: 33 Points: 2,937, Level: 33 Points: 2,937, Level: 33
Activity: 0.5%
Activity: 0.5% Activity: 0.5% Activity: 0.5%
graff_hip_hop@yahoo.com DESKSECTOR
man bro...fkn cheap *** mechanics like that make us good mechs.. look bad one thing i could tell you that fu just wanted to get you to pay him and you go on your way with a 50% rebuilt engine..all he had to do is get paid and wash his hands..if you take him to court ask for parts receipts cuz -obviously he had to get the parts from a store cuz i doubt he manufactures them lol...and he cant say is customer abuse cuz those pieces are part of a valve is impossible to shred a valve like that by pushing the engine beyond its point you would of most likely overheated the engine or blown a piston...but not shredded a valve sound like second hand parts and restarted Assembly..only if you lived in la..=/best of luck on your situation..and tell the judge VQ's would never go down so easy like that lol
graff_hip_hop is offline   Reply With Quote
Old 02-03-2012, 08:22 AM   #20
Points: 11,996, Level: 71
Points: 11,996, Level: 71 Points: 11,996, Level: 71 Points: 11,996, Level: 71
Activity: 99.3%
Activity: 99.3% Activity: 99.3% Activity: 99.3%
aackshun
Send a message via AIM to aackshun
__________________
This is a game for ballers only ballers can participate
REGISTER FOR MAXUS
-$45 for base package, $65 for racers. Details on the site, any questions PM me!
after all that, this is what i comes down too. Now this is trolling of the year.
aackshun is offline   Reply With Quote
Old 02-03-2012, 08:23 AM   #21
Boosted Panda
Flava_24/7's Avatar
Activity: 2.8%
The adapters came directly from Stephen, he is local to me and actually drove to my work, sat in my office and handed them to me personally.
__________________
Old 02-03-2012, 08:24 AM   #22
Boosted Panda
Flava_24/7's Avatar
Activity: 2.8%
Quote:
Originally Posted by aackshun View Post
Yup, sux for me. Not sure how long I will be down now.
I REALLY dont want to give up on this car just yet but my family and close friends all keep saying to let her go.
Now Ive spoken to the builder this morning and informed him of the situation, first thing he said "its a race engine, cannot warranty a race engine". I laughed and told him its not such a thing. He should know, he purchased the parts. Every part that went in is OEM.
Then he stated the cams I provided were for a race engine and I informed him nope, that they too are OEM and I provided the correct OEM valve springs to be used with those exact cams.
So then he said it must have been too much boost, and I reminded him that my setup was not new. Ive been boosted for years and never had issues like this. I reminded him that my previous motor had way more miles on it and took all the abuse I could throw at under boost and that a freshly built motor should be able to do the same, not give up after 3k miles. I even reminded him that he told me when he was done building the motor, it would be solid and not give me any problems.
So now hes saying that its definately something with the valve train and wants to know:
1. If one of the springs broke
2. How much more tesnsion the HR valve springs have over stock A32s
3. differences in the valves in the Z33 HR vs A32 (material type, size,etc.)
Looks like Im going to have to tear into it to see where the damage is. He is telling me that he will do what he can to make it right,. and that the machine shop assembled the heads so he will be speaking to them but would like to know the requested info before hand.
Anyone know the specific details in the differences between the valve springs and valves between the Z33 HR and Maxima?
Times like this is when Dave B was extremely helpful.
__________________
Old 02-03-2012, 09:00 AM   #23
McSteve's Avatar
Activity: 10.0%
sorry to hear about your misfortune man! Don't let her go. If that guy doesn't wanna make it right just take your time and fix it up yourself.
__________________
MODS:
Old 02-03-2012, 09:27 AM   #24
Activity: 100.0%
Crusher103
i like how the builder is trying everything to find an excuse. Everything is all "Oh its racing nothing i can do." i have heard some excuses like those when i had suspension done back in the day how "they are big bolts and they work themselves lose", really? But way too much work in this car to get rid of it for pennies. This will leave a very sour taste in your mouth if you do.
__________________
Old 02-03-2012, 09:57 AM   #25
Points: 5,172, Level: 46
Points: 5,172, Level: 46 Points: 5,172, Level: 46 Points: 5,172, Level: 46
Activity: 2.6%
Activity: 2.6% Activity: 2.6% Activity: 2.6%
dont give up on your car because of this. a quick swap and its new again. but what you have to do is take motor apart and find out what really happened. i think cam adapters could of failed. you can start by taking off timing chain cover and valve cover and check the adapters
TurboA32 is offline   Reply With Quote
Old 02-03-2012, 12:42 PM   #26
Activity: 2.6%
what did you get done to the motor?
Old 02-03-2012, 01:03 PM   #27
Blown
Points: 21,797, Level: 92
Points: 21,797, Level: 92 Points: 21,797, Level: 92 Points: 21,797, Level: 92
Activity: 5.5%
Activity: 5.5% Activity: 5.5% Activity: 5.5%
Send a message via AIM to cardana24
Good luck man! Don't give up on the car over this.
cardana24 is offline   Reply With Quote
Old 02-03-2012, 01:04 PM   #28
Boosted Panda
Flava_24/7's Avatar
Activity: 2.8%
Quote:
complete rebuild, new pistons, rings, rods, etc and then the head was machined, new valve train with the Rev Up cams and HR valve springs.
__________________
Old 02-03-2012, 01:07 PM   #29
Boosted Panda
Flava_24/7's Avatar
Activity: 2.8%
So I found the specs for the HR valve Springs, 113-127lbs @ 26.2mm
Anyone know the Specs for the A32 Valve springs?
Also, does anyone know if the differences in the Z33 HR valves vs the A32 valves such as material made of and etc.?
__________________
Old 02-03-2012, 01:10 PM   #30
Boosted Panda
Flava_24/7's Avatar
Activity: 2.8%
Quote:
Thanks, I really dont want to but theres no way I can afford to shell out a few grand to do this all over again. It will all depend on what happens wit the builder.
I guess if worst comes to worst I can buy a cheap 3.0 and drop it in and call it a day and be boosted again.
__________________
Old 02-03-2012, 01:18 PM   #31
Blown
Activity: 5.5%
If you have the time you should really consider putting the engine together yourself, it will save you a ton of money and you will know it's done right. There is tons of good info. in the all motor secton on engine assembly. If you were closer to VA I would be more than happy to help you.
Old 02-03-2012, 01:20 PM   #32
Activity: 2.6%
so there wasnt any double shim valves or anything unnecessary like that?
Old 02-03-2012, 01:22 PM   #33
Activity: 2.6%
this would be your best bet.
Old 02-03-2012, 01:26 PM   #34
Activity: 2.6%
100% with you. and the FSM is a good guide to
Old 02-03-2012, 01:29 PM   #35
Activity: 100.0%
Crusher103
This.
Just if you do make sure to seal the damn timing cover correctly, because that can be a headache. But its not as bad as most people thing it is and i believe your block atleast is salvageable. As long as you are not porting etc having headwork done is not expensive.
__________________
Old 02-03-2012, 01:44 PM   #36
Boosted Panda
Flava_24/7's Avatar
Activity: 2.8%
I have the time, just not the space. i dont have a garage, it was converted to a game room before I bought my house. A buddy of mine has offered to rebuild it for me if I want to go that route. Hes a mechanic for Infinity and been there for at least 5 years, before that he was at Nissan so he knows the Maxima vey well. He is just unfamiliar with all the hybrid setup Org members are doing nowdays LOL
No double shims, many told me I didnt really need them with the HR valve springs, I did have the HR headbolts use though.
This.
Well, Im sure something is gonna have to be done to at least one cylinder, no way that valve made its way into the cylinder and out the exhaust without scoring the wall.
__________________
Old 02-03-2012, 01:52 PM   #37
Activity: 2.6%
what kind of pistons and rods and is this a 3.0
Old 02-03-2012, 01:56 PM   #38
Boosted Panda
Flava_24/7's Avatar
Activity: 2.8%
Yup, 3.0 and OEM from what I was told (most likely OEM equivelant and not dealer parts though)
I do still have another motor laying around though that we could build up if needed to be. That motor had the spun bearing.
__________________
Old 02-03-2012, 01:59 PM   #39
Blown
Activity: 5.5%
[quote=Flava_24/7;8350914]I have the time, just not the space. i dont have a garage, it was converted to a game room before I bought my house. A buddy of mine has offered to rebuild it for me if I want to go that route. Hes a mechanic for Infinity and been there for at least 5 years, before that he was at Nissan so he knows the Maxima vey well. He is just unfamiliar with all the hybrid setup Org members are doing nowdays LOL
QUOTE]
That's nice that you have a friend to help. Tell him it's just like assembling any other VQ. Since you are using different cams just remind him to re check the lash once the cams are installed. I was able to swap a bunch of mine around to get with in spec, and only had to buy two new. Once that is done then getting the timing set correctly is the last big hurdle, and it is not as scary as you probably think...and prime your main tensioner before putting the outer timing chain cover on....that's all the advice I have for now.
Old 02-03-2012, 02:10 PM   #40
Turbo 3.5
Activity: 7.8%
Good luck, I'm still thinking the cam adapter or dowel pin failed. In for the results when the motor is torn down.
Btw agreed just drop a stock vq in there and enjoy
__________________
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Advertising - Terms of Use - Privacy Policy - Jobs - Contact Us - Maxima Forums - Archive - Top
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.5.2
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
