Look inside---i30dvr's turbo setup
#44
you can weld the radiatior if you can see the leak, i would almost venture to say an oem honda unit rad/fan may work better than those china aluminum units, though if you will buy the ebay onel with a shroud would be my choice
#46
ok so heres the deal...car is back running but my temp gauge stays in the middle but if i accelerate easy/or hard above 3k u can see the temp go down towards cold and then back up when u left off? could that be a sensor or a stuck thermostat open? what you all think thanks
#51
I'd think if the stat was stuck open the car would take forever to warm up and the actual coolant temperature would still be about the same. The t-stat is just a switch that changes the direction of coolant flow once a certain coolant temp is hit.
Hook up a secondary water temperature gauge and see if it's actually behaving that way or if your gauge/sender is just freaking out.
#53
ok so the car as of now is fixed. I don't know which did it but i replaced the thermostat as well as the coolant temp sensor (2 pronged one). went out for a drive after letting it warm up w/ the rad. cap off till it gurgled out. temp was in the mid. the whole time...woo hoo lol. now just gotta get that clutch in so i can really turn up the boost.
question- what is the other little sensor directly in front of the coolant temp sensor (spade connector). i haven't replaced it but is it a switch for the factory fans?
#55
#57
hopefully like 14 to 15 lbs...16 degrees of timing.
so i drained my coolant once again because i made the mistake of putting a whole bottle of water wetter in there when only suppose to use like 2 oz. filled it back up w/ distilled water and 100% antifreeze mix. i'm hoping the problems are gone but i let it idle for about 20 min w/ out the fan on to get the gurgling out and then did a 2nd gear pull to about 5300rpm and then pulled back in my neighborhood and when i made the turn in i saw the temp gauge rise above normal then even higher by the time i pulled in my driveway. i'm hoping this was due to letting it run for a while w/ out fan on then doing about 20mph till my pull then back down to get back into my house. i did turn the fan on before the pull but i think it was too late lol.
any input on putting a 2nd fan on the front of the radiator? i know hal had his setup like this but idk if he had 2 or just one on the front.
#58
Just sell all that **** up that has caused you nothing but problems and buy my turbo kit like i told you from the begining. You would have you A/C, your entire rad, your two fans.....everything pretty much like if it was stock and with a nice GT35 Full stainless pipes and greddy intercooler. hehe...but nooooo.......... So keep fixing that **** LOL...
#59
fyi at 16psi just beware that you are going to blow a head gasket if you have not already upgraded them. Not saying it will happen the 1st, 2nd or 3rd time out but over time it will go.
#60
did u have the fan running on the back side of the rad right next to the downpipe? i'm just thinkin that maybe the dp is getting so hot that the radiator fan motor is actually cooking lol. i was looking at pictures of hals original setup and it looked like he had the fan on the front of the radiator away from the dp. idk if he had two fans or the reason so install in front vs. behind. what do you think of any benefits/neg. effects by moving the fan to the other side.
also could the intercooler be taking away that much air that runs over the radiator? its now 2 times the size but i figure air would just go through that into and through the radiator as well....
#61
i dont think the intercooler is an issue, i had prob the biggest front mount ever put on a maxima, and i never had any cooling issues bc the front mount. wrap the dp, put a fan w a shroud and cross your fingers that half a radiator will be enough to keep it cool. that fan youre using is not going to work for a real daily imo....
did you gut the second thermostat? stick to 13-14 psi
#62
#63
haven't gutted the t stat yet but yea the dp is wrapped now and spraying w/ the silicone spray. i'm hoping i can fit a shroud in there. the stock honda fan is way too deep and won't fit on the front or the back side lol
#64
i daily drove my max everyday with that kit on my car, i had the fan constantly running as soon as i put the car in the ON position, just get a better 10-12in fan w/ metal blades if you can and put that fan on the front
theres no need to be cutting thermostats out and all that stupid non sense
#65
#66
well i mentioned it to him bc i had my car start warming up after several hard highway runs, and the 2nd thermostat that the dek has, was the issue, that stat which the de doesnt bring. im my opinion, loosing ac, using half a radiator, and this entire kit as a whole is stupid nonsense.. not to mention the entire piping and bullsh8t *** intercooler it came with ... straight up ngrig
also any pic's cause the original owner didn't cheap out on the parts so nothing should have been rigg'd but then again that was like 2yrs ago
#67
I don't understand why you guys are giving him such a hard time about the a/c he is a grown man that knew ahead of time he couldn't retain it without some custom lines. Can't speak for the seller cause I don't know him but thats what I told him.
#69
hey man how much of a "daily" was ur car. i mean i drive about 6 miles to and from work but there is a bunch of traffic lol. idk if i should buy a 2nd fan for the front of the rad or just move the other one. i def. need to figure a way to keep it from getting hot because this is not realistic at all. i get off work at 6pm but i just got home now because i hang out till 8pm or so once traffic dies down. any idea how much cfm that fans flows? bc i found some on jegs/summit that supposedly flow like 1500+ and i'm wondering how accurate and if thats true if it would keep my temps down.
#70
btw, I would just get a cheap stock fan from yard mod it for the front have it turn on with the car and the 2nd fan at a pre set temp. if that does not work I would check for air in the system cause the rad installed on the orig car was a half rad but twice the thicknest of a stock maxima rad so it was wash
#71
im very curious as to what about the intercooler and the piping was rigged, and what your definition of rigged means..if you dont wanna loose ac thats completely up to you, i put my car up that kit will out preform any maxima turbo/supercharger kit youve had or ever will have, you wont ever have a kit that starts to spool a turbo of that size at 1500 rpms so your opinion is completely non sense cause at the end of the day it isnt your kit
#72
the original owner drove with that rad for 2 months before the kit was on and about 3 weeks after the kit was on and the whole time he had it he was on 10-12lbs of boost, i drove with it for 4 months on 5lbs, i never had a prob with it neither did my boy whose kit it was originally for
#73
as the original owner of the kit im offended you said my bull**** i/c n piping was rigged.. it was great because the car never over heated, the rad got plenty of air, and i NEVER blew a coupler once. Yea i lost a/c so what? the kit was made to spool fast. If it can spool up a holset hx35 at 1500 rpms imagine a smaller turbo? Nothing on it was rigged, it was all done for a reason
#74
u know i'm not saying ur **** is rigged. i personally love the setup but i'm dealing w/ issues w/ it getting hot. it doesn't help that the past week has been on average over 95-98 degrees. tomm is suppose to be 103! lol. i ordered a crazy fan last night that will go on as a pusher and flow about 2200 cfm vs. the fan thats a puller on there now is only flowing about 850ish. hopefully this will solve the heat issue. other than that the kit is awesome. i've made some changes like a larger intercooler and made a new pipe that connects to the downpipe that is tucked up higher so slammed guys like myself won't have to worry
#77
I will say this... your intercooler was a joke... size of a stock eclipse unit lmao... iirc piping I saw had jbweld ... more couplers than god knows what,... yeah the spool must be nice, but i spooled a full q trim t04 to 10 psi in 1st gear by 3500 rpm no issues,..... maybe you should make another pos kit and put down a dyno of 393 whp like i did at 10 psi, then come holla at me.... with ac, no heating issues, and a real massive intercooler, ..... dont take it personal, it is what it is, the feed pipe is great, for a race car, everything else was dog sh*t, and for a real daily, it aint working..... lets just say... the kit matched the rest of the car it came off of...... thats my opinion .
#79
#80
How was the intercooler a joke? because it wasnt 32' long? and 12' high? it was a 18x7x3 iirc which last time i check is bigger than any stock dsm I/C, the bov flange and the bung for the iacv bung was jb welded to ensure that it wouldnt leak which it didnt, had a brand new Tial 35mm wastegate, TurboXS rfl bov to ensure no compressor surge, 3ply couplers w/ all tbolt clamps, maybe 6 couplers it total with only 4 90 degree bend and prob only a foot of str8 pipe, a brand new autometer boost gauge, a Brand new greddy oil sandwich plate .........so what here is dog **** again?
and you needed a "Massive" intercooler to make only 393whp? like are you serious, do you hear yourself ? the OP paid $800 for a kit that ran close to $2200 to make.. a setup which WOULD/WILL out preform any kit you HAD on your maxima, and did you ever see the maxima this kit was on? it was prob cleaner than your car with original paint
