4th gen Charge pipes in 5th gen, and other Q's
Ok so after alot of debating, Im going through with the install, but have not found anything describing how to successfully install a 4th gen s/c to a 5th gen. I've searched and searched, but my knowledge of boosting is limited and Im trying my damndest to learn without having to start new threads. I've read alot of how it will work with modification but that was the extent of it. What exactly is needed to make the 4th gen charge pipes work on my 5th gen? Write-up perhaps? Or would it be easier to just look for some 5th gen charge pipes? Also,i just read that 5th gen owners dont need to install the z32 MAF to have the s/c run correctly. Is this true? If I dont need it what do I need? Any help or links is greatly appreciated.
ahhh helll! Is there any other maf that would work on a 5th gen? I need all the guidance I can get. I never once saw anyone mention another type of MAF, just always seen the z32 used for s/c applications.
EDIT: Just did some more searching and I might of found my answer. But I will glady accept any further help!
http://forums.maxima.org/supercharge...sc-piping.html
That thread will answer your questions about 4th gen piping on a 5th gen. And like Kevlo said, you can go with a Land Rover MAF, but need a way to tune for it. You could run the stock MAF and just see where it maxes out. How much power are you looking for?
I am going to be using the 13lb pulley. Any more power than what I have now is better than nothing. Im not sure how much more power to expect. But Im going to stick with the stock MAF. Where does the stock one max out at more or less?
I plan on getting a wideband and already have a emanage ultimate at home. Another noob question, is it just the housing i need or the whole thing, housing and maf?
Ok never mind my earlier post, Im assuming the whole MAF. I havent slept yet and been busy all day. sorry if it seems like I am not reading the posts
I have the 5th gen piping for sale and the recirculation valve, couplings and everything else needed . Plug and play no thinking required. Take a look, l will give you an awesome price too.
http://forums.maxima.org/forced-indu...ther-misc.html
You don't have many choices if you own a 5th gen, your MAF won't tolerate being on the charge side like the 4th gens. And you can run a 13 lbs pulley, no problem, l did 11 lbs with these pipes.
I might of found my charge pipes, maybe, but where do I get the hoses that are connected to them? And on the charge pipe that runs through the top WTH is connected to it from the right side (facing engine). i see it just drops down into the engine behind the radiator, Ive done countless searches and no good clear pics to answer my question. The more I learn about s/c'ing the more I find out that I still need more guidance.
But Im trying. so bear with me.
But why not just do a setup like this?
It looks all good from the picture. but isn't the common misconception, the fact that the 5th gen OEM MAF doesn't like to be on the charge air side of the blower piping. Hence the reason Stillen designed the 5th gen pipes to have the OEM MAF on the intake side of the blower. Maybe that picture is an example of how not to do it, not how to do it.
Well I've seen many run it this way. If you read the info posted in the thread linked earlier it explains how its totally doable with no ill effects.
My MAF is on the charged side and I have had no issues with it whatsoever. The car Flava posted is a car that is local to me and that car dynoed 300whp a couple years ago and he has had no issues with the MAF.
Maybe you misread my post OEM 5th gen MAF. Not A rover MAF not a different housing but a OEM 5th gen MAF. Wow sometimes l think some of you are so bored that you look for confrontation. And maybe you should phone Stillen and tell them that they had it all wrong according to you.
Maybe you misread my post when l wrote the words, OEM 5th gen MAF. Not A rover MAF not a different housing but a OEM 5th gen MAF. Wow sometimes l think some of you are so bored that you look for confrontation. And maybe you should phone Stillen and tell them that they had it all wrong according to you.
I would do the 4th gen piping because I read and found out that the way that stillen did the 5th gen piping chokes the engine at around 120 or so and when secondtonone did his 5th gen with 4th gen piping using the stock MAF on the charged side said he had no problems sticking the needle at 160. Not that I would be doing that very often, just nice to know that its capable of that. I just read conflicting stories about the MAF on the charged side not doing good there, but was told to put the MAF in the upright position. I'm going to give it a shot and go with the 4th gen pipes for now, but might grab some 5th gen pipes as back ups just in case my MAF doesnt cooperate.
I was refering to an OEM MAF as well. Not all use the Land Rover MAF, just like not all 4th gens use a Z32 MAF. Even in that link nismomaxct posted, secondtonone317 stated he ran just fine with it. Of course he was preparing to go with a larger housing later but that didnt change the fact
No one here was looking for confrontation, well other then youself I guess.
We are just stating simple facts based on other users experience.
Just because Stillen stated to put it on the non-charged side doesnt mean it cannot be applied to the charged side, because obviously its been done by other members here according to them, NOT ME.
