divided manifold
divided manifold
i have a vq30de and i am going turbo but debating if i should go divided manifold or not.
my set up will be a completely stock had and block vq30de...
arp head studs
cometic custom head gasket for stock bore
probably getting a gt35r to gt40r or something comparable...
7xx-8xxcc injectors
tial 38mm or 44mm wastegate
tial 50mm bov
greddy emanage ultimate
let me know what you think...and if you got any advise...looking to make the most power...if the motor goes, i have a spare one...
arp head studs
7xx-8xxcc injectors
tial 50mm bov
If you are keeping the motor stock, I think a divided manifold may not be worth the extra effort. You can make plenty of power and enough to blow your motor without the divided manifold. However, I have always wanted to see what a nice, equal length piping setup would produce on a Maxima. I have thought about doing it on my car, but I am happy with the power my turbo setup is producing now. I believe if you were to do some sort of divided manifold setup and you were having each bank feed each turbo scroll equally you would need it to meetup just over the transmission. It would look somethnig like this.
Sure, you can buy the one I'm making for cheap as I am just trying to get my money back. I was making it for myself thinking I would have another maxima by now. I also thought this could be done without having to mod anything. To run this setup you will need to replace the drivers side fan with a pusher or a slim fan. And if you have a car with mechnical egr setup either remove or mod it. And last naturally swap the headers all of this is no big deal but I am lazy and don't feel like dealing with the rear header removal or install.
arp head studs
7xx-8xxcc injectors
tial 50mm bov
arp head studs
7xx-8xxcc injectors
tial 50mm bov
Is there a reason you need such a large turbo? If you are staying stock (I have no idea what kind of power the vq motor can make before it pops) but let's say 20psi. That is not even enough to wake up a 35r. They will perform best at least at 26psi or higher and I can't see you running that much.
The GT35 is a great turbo on the VQ. You do not need to run anywhere near 26psi to wake it up. In the 10 psi range, that turbo will put down some nice power on a VQ and spool up fairly qucikly. The 3.0 will be fine in the 400whp range with a good tune (which is around 10psi on the GT35).
