2.5" or 3" exhaust
Old 07-13-2010, 11:26 PM
akurtzer57's Avatar
2.5" or 3" exhaust
This is mainly for the guys in the 400whp range. Which is my goal. Are you guys running 2.5" or 3 inch. Any input would be appreciated.
akurtzer57 is offline
Old 07-14-2010, 12:49 AM
HotshotVQ35's Avatar
NA guys with 250 whp are running 3" SO yeah go 3"
HotshotVQ35 is offline
Old 07-14-2010, 01:21 AM
akurtzer57's Avatar
Im looking to see if 2.5" is efficient up to 400whp. People with hondas that make 160whp run 3 inch doesn't mean it is needed.
Old 07-14-2010, 04:17 AM
Black Lion
maxprivate's Avatar
From what I have been reading up on so far, you have to have 3" DP and exhaust or you can starve the turbo of boost. Im will be going back to stock headers (currently have Cattman headers) and swapping Cattman catback to 3" exhaust.
maxprivate is offline
Old 07-14-2010, 06:59 AM
My axles cry for mercy...
essential1's Avatar
For the most part when dealing with turbos, bigger is better. Bigger exhaust means lower EGTs. That in itself should convince you to go atleast 3". Also, its been known that a restrictive exhaust can cause boost spikes and peak boost may not hold through out the power band. Which, as you probably know already, can cause a momentary lean situation that can lead to catastrophic failure.
Sure a 2.5" exhaust can work in a 400hp application, but you shouldnt dwell on just power. The safety/longevity benefits your motor gains outweigh the power.
essential1 is offline
Old 07-14-2010, 08:41 AM
SLOW
Nealoc187's Avatar
no question, 3". the benefits go way beyond just the peak power number. spool time will be helped significantly, better wastegate functioning (assuming external gate) etc. you can never have too large of an exhaust on a turbo vehicle. larger is always better when it comes to post-turbine piping.
Nealoc187 is offline
Old 07-14-2010, 08:52 AM
maxmaxima91's Avatar
Do this
maxmaxima91 is offline
Old 07-14-2010, 11:12 AM
akurtzer57's Avatar
The only problem I have is I am might have to have a choke point on my downpipe. I might not have enough space to go 3 inch. So about a foot or so has to be 2.5" Ill have to deal with this soon. Ive been debating what to do here. My down pipe goes down between the motor and firewall.
Old 07-14-2010, 12:43 PM
SonicDust187's Avatar
Use oval piping.
SonicDust187 is offline
Old 07-14-2010, 02:12 PM
RedBeauty84ZX's Avatar
Go 3 inch.
In a turbocharged car the turbo itself is enough air restriction for the exhaust gases that anything else will just hender the turbos efficiency. In other words you want the most free flowing exhaust piping after the turbo as you can get, generally a 3 inch mandrel bent setup is sufficient for most setups.
RedBeauty84ZX is offline
Old 07-14-2010, 06:20 PM
KH3 by popular demand
maxgtr2000's Avatar
You shouldn't even really be considering less than 3" in your application. I have 2.5" and it can spike pretty quick, in a way I wish I went with 3" from the get go and mine is just a dd hoping for a little over 300whp.
maxgtr2000 is offline
Old 07-14-2010, 06:57 PM
Black Lion
maxprivate's Avatar
From what I understand you have to go 3" after your stock headers. Plenty have done it so I don't know what the issue is. Check out Kazoosho, he's the one who filled me in on it.
Old 07-14-2010, 07:09 PM
akurtzer57's Avatar
um Im 3rd gen. Custom headers I made. There isn't much room between firewall and motor on a vg30e.
Old 07-14-2010, 07:11 PM
BkGreen97's Avatar
you can save money and go 3" electrical cutout? if its your daily driver.. All the 3" exhausts i've heard personally tend to be on the louder side..
My setups is soon to b 2.5" stillen catback and 3" qtp electrical cutout in place of the cat.. I have a 3" downpipe up until the cat by the way..
BkGreen97 is offline
Old 07-14-2010, 07:22 PM
Black Lion
maxprivate's Avatar
ahh got ya. thought you were a 4th gen. It does suck having to upgrade. I have Cattman headers and full catback, now I will be switching to 3".
Old 07-14-2010, 09:12 PM
streetzlegend's Avatar
3" is a REQUIREMENT with turbo setups (in my book).
streetzlegend is offline
Old 07-14-2010, 09:14 PM
krazy6's Avatar
At least 3"
krazy6 is offline
Old 07-14-2010, 11:57 PM
maxgtr2000's Avatar
3" probably would be cheaper than this, but this does have a "coolness" factor too it, ha ha.
Sound Performance Boost activated cutout.
This maybe more reliable than an electric unit.
Old 07-15-2010, 03:41 AM
Turbo 3.5
t6378tp's Avatar
Mmmm I like this idea
edit, seen the price and since I already have a cut would rather get the electric part with a boost switch. I my just do that instead of a 3inch exhaust
t6378tp is offline
Old 07-15-2010, 09:36 AM
akurtzer57's Avatar
That don't look to hard to make. Might have to tackle this one. Just order me a manual cutout and modify it to accept a Internal waste gate. I have a few laying around. Set at 7psi. Once it 7psi should open up. Maybe even run a solenoid in the vac line to turn on and off as needed.
Old 07-15-2010, 11:21 AM
krazy6's Avatar
How would that work? A manual cutout just has a block off plate, not a flapper door.
I think the way to do it would be to use a hobbs switch to control the opening of an electric cutout.
krazy6 is offline
Old 07-15-2010, 01:46 PM
Just get a regular electric cutout, hook it up to a hobbs switch and your done. SP is extremely overpriced for what they sell.
Old 07-15-2010, 05:31 PM
akurtzer57's Avatar
thats why I would make my own
Old 07-15-2010, 10:39 PM
maxgtr2000's Avatar
My thoughts exactly.
Old 07-15-2010, 11:58 PM
akurtzer57's Avatar
Looks like have to make one from scratch. They only make the pull type cutouts in cast iron y pipes. So Probably order me a 3 bolt flange and find a 3" throttle body. Rob the butterfly valve and you get the idea.
Old 07-16-2010, 09:37 AM
SLOW
Nealoc187's Avatar
i wouldn't do a cutout again as I think they sound like ****, and definitely not a boost activated one. the last thing I want is my exhaust randomly going from decently quiet to loud and sh!tty sounding because i floored it for a second trying to get on the highway or whatever.
A 3" exhaust with a good large resonator and a good muffler will be nice and quiet and flow perfectly fine for 450whp.
Maxmaxima91 has 4" on his car and his car is really quiet. it's all about the resonator/muffler combination you choose.
Old 07-16-2010, 10:34 PM
Grand_hustle17's Avatar
If you had thoroughly read what hotshot said you would get the answer from what he's saying.... he wasn't talking about other model cars... if guys that have the same car like you have runs a 3" piping and it made for better flow and increase in power in N/A form then wouldn't it be common sense that on a car that's probebly making almost twice as much power that this would be sufficient???.... (extended version I guess)
Grand_hustle17 is offline
06-06-2017 02:01 PM
Justin Kroll
10-01-2015 07:03 PM
09maxshawn11
09-30-2015 10:28 AM
Socalstillen
09-26-2015 12:01 PM
TheMafia
09-04-2015 08:26 AM
Quick Reply: 2.5" or 3" exhaust
