Go Back   Maxima Forums > Advanced Performance > Supercharged/Turbocharged
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 11-03-2009, 10:35 AM   #1
Send a message via AIM to streetzlegend Send a message via Yahoo to streetzlegend
Rich out-of-boost after muffler delete
So, I removed my muffler and put a straight 3" pipe, its awesome, i gained 3psi of boost, etc...
The issue is, my idle AFR is dropping to the low 11's. Usually with muffler on its always at 14's. After I go for a drive, and say I get into boost and then drive normal again, once i come to a stop or idle AFR is back in the 14's. Can someone explains this to me? Can it be that after I get on the gas, the turbo starts spinning and basically keeps spinning freely since there is no restriction in turbine outlet causing for more air to be flowing into the manifold at idle, possible?
Should I just give it time so the ECU can get used to the new maf readings?
For those not familiar with my setup, I dont have o2 sensors. My ecu runs open loop all the time and I manually tune it myself via EU.
__________________
Streetz goes into the 11's!!!
440CC RC injectors for sale, $220 Shipped. PM ME
streetzlegend is offline   Reply With Quote
Old 11-03-2009, 06:26 PM   #2
possibly faulty fuel pressure regulator? if you boosted more than you normally do and then it broke it could just be the extra psi that it saw that broke it?
__________________
mywhitewolf is offline   Reply With Quote
Old 11-04-2009, 08:40 AM   #3
Problem seems to be fixed, I put in the stock injectors and car idles perfectly a/f stays solid. When i took off the 440cc RC injectors one of the o-rings was actually blocking the tip of the injector (I had doubled up on the o-rings, big mistake). btw regulator is perfect, fuel pressure is solid.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
