Go Back   Maxima Forums > Advanced Performance > Supercharged/Turbocharged
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-26-2009, 09:31 PM   #1
Send a message via AIM to DTrem08
Injectors
So Im planning on running a 10 psi supercharger setup and know Im going to have to upgrade my fuel system. I'm assuming I need the walbro 255 fuel pump, but Im not sure how to figure out/what size injectors I need. Also, what else would I need? What ratio FMU etc
__________________
99 SE 5MT Pearl White
Coilovers. 18" Rims. Pirelli. Intake. Megan Catback.
25% Tint. Alpine. Infinity. Kicker. Rockford Fosgate.
DTrem08 is offline   Reply With Quote
Old 10-26-2009, 11:14 PM   #2
SLOW
Nealoc187's Avatar
Send a message via AIM to Nealoc187
For 10psi supercharged purple top 370s would probably be sufficient, perhaps with a little bump in fuel pressure. Purple top 370s actually flow ~410cc @ 3.0 bar of fuel pressure. A better purchase would be something in the 450-550cc range, you can keep your fuel pressure lower and IDCs lower that way. Either way you'll need something to tune with, at least an SAFC, preferably either EB or EU so that you can adjust timing, and fuel maps better to get a smoother tune and monitor more parameters, and almost certainly an AFPR. FMU is not needed if you upgrade your injectors to a proper size. Yes you'll need the fuel pump.
Also that sig pic is way too big, you need to cut that down to size to abide by forum rules.
__________________
95 SE - Stock 3.0L w/ USIM - T61/P-trim @ 14.5psi - 93 octane
11.76 @ 121 - 1.82 60' - ET Street DOTs
12.15 @ 123 - 1.95 60' - Nitto DR
3.5L swap with I/Y/E
12.92 @ 104 - 1.69 60' - M&H Slicks
13.60 @ 103 - 2.15 60' - Street tires
96 GXE - I/Y/E/MEVI/JWT ECU
13.42 @ 102 - 1.87 60' - M&H Slicks
13.82 @ 102 - 2.17 60' - Street tires
95 GXE - Stock winter beater
14.28 @ 95 - 2.07 60' - Street tires
High Flow Fuel Injectors
Injector Cleaning & Servicing
www.DeatschWerks.com
Nealoc187 is offline   Reply With Quote
Old 10-27-2009, 08:08 AM   #3
So 370cc injectors would work, but 450-550 would be better?
Regardless, I figured I needed to get an SAFC. Haven't looked into AFPR's yet.
As long as I get larger injectors I dont need a FMU? What if I just kept stock injectors and got a FMU, would that work?
__________________
Old 11-07-2009, 06:04 PM   #4
I'm trying to boost with stock DE injectors 'till I get a '00VI and bigger injectors. So far I have a walbro 255HP, aermotive fpr, and fmu. I'm still searching for the right amount of boost to run. A 3.33" pulley on my V1 should be about 9psi. What the FMU does is raise the fuel pressure but if you have larger fuel injectors you wouldn't need to do that and the injectors wouldn't work as hard. Stock injectors and a FMU will work, just need to figure out how much boost you can run. If I find a thread with the info. I'll let you know. Hopefully someone will have allready answered your question by then.
__________________
SHIFT_NFS
Quickywd01 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
