Go Back   Maxima Forums > Advanced Performance > Supercharged/Turbocharged
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-12-2009, 10:54 PM   #1
Un-Built VQ35??? Boost??calling out those who have blown them
So I have a 97 swapped VQ35 ith 3.0 timing. Thinking about starting tpo piece together a power adder as money permits. and by power adder im thinking turbo or n2o
i have seen a ser altima boosted with a gt35 at 8 psi and it made around 380 from what i remember. but it was auto and shortly after getting beat by a vq3.0T he took the kit off. he was boosted for about 3-4 months so im not sure how long that 3.5 will live.
im wondering whats the most boost TURBO guys ar running on the stock bottom end 3.5s??? how much power can these engines safely take??
100 shot wet is the other option, but i hate refilling , turbo never runs out
thanks for the input guys
aic96max is offline   Reply With Quote
Old 10-13-2009, 12:36 AM   #2
KH3 by popular demand
maxgtr2000's Avatar
Send a message via Yahoo to maxgtr2000
There is a forced induction section on my350z.com that I frequent to learn more about the vq35. 380-400 on boost is okay but any more than that it and you will need rods. They seem to be a weak point on these engines once you start adding boost and start to exceed 400 whp. Chernmax's engine acted up because of piston rings but when he broke the engine down some of the rods were bent as well. Chern's rod pics
A list of 50 boosted vq35 setups, mostly stock blocks.
__________________
Retrofit headlight services
My VQ30DET
Emanage Blue and Ultimate Forums
There can be no peace until you possess the Prince of Peace.
maxgtr2000 is offline   Reply With Quote
Old 10-13-2009, 10:33 AM   #3
Send a message via AIM to streetzlegend Send a message via Yahoo to streetzlegend
Yea I alvaro there is a thread that has a list of everyone that has boosted their stock blocks and they show how many miles it lasted, at what boost they were at, and if they are still driving with it.
Cliffnotes from that thread: dont go above 400whp (although some have and still running around, better to be safe).
__________________
Streetz goes into the 11's!!!
440CC RC injectors for sale, $220 Shipped. PM ME
streetzlegend is offline   Reply With Quote
Old 10-13-2009, 06:40 PM   #4
I'm on 9psi and methanol injection... I'm going to try an 11psi pulley in the next coming weeks. I'll keep you in mind when i blow it up lol
edit::i just realized you asked for turbo guys lol.
__________________
|VQ35DE w/3.0 timing Components|Vortech V2 SC w/ 3.33" pulley|440cc Injectors|AEM Methanol Injection|y-pipe|3inch exhaust|KSport Damper|Stillen Lip Kit|Carbon Fiber Hood|Work Equiped
emdot is offline   Reply With Quote
Old 10-13-2009, 06:51 PM   #5
Send a message via AIM to digitalbow
My old block saw double digits on occasion, however 6-10psi was my 'safe' range. Good tuning matters so much more than pressure. Rock solid tune on a dyno, or road tuning - crucial. Get it done on C16 then go back and do your timing map on your pump gas. You can skimp on the 'build' if you're not going for a serious power goal, but don't cut corners with your tuning.
My old 3.5 eventually gave and I have a new one, but the last one was worsening due to oil consumption, not boost.
__________________
digitalbow is offline   Reply With Quote
Old 10-13-2009, 07:44 PM   #6
dam, not sure a 350 whp turbo car will be faster than a 100 shot of Nitrous car , will have to do some thinking for sure, altough 350 whp will always be there and will never run out.I will def look into the 350z forum, has anyone got away with standard size pistons???
streetz did you go over sized at all or stock bore? your main and rod bearings are standard or did they need machining ?
Old 10-13-2009, 11:51 PM   #7
SLOW
Nealoc187's Avatar
Send a message via AIM to Nealoc187
I have no intention of building my 3.5 and I am going to run in the 450whp ish range, maybe more if I feel frisky once the setup is completed and worked out if it's not putting down the track times I'm looking for. Of my buddies with 350zs, all of them are boosted (4) and all of them have made more than 470whp on the stock motor, none of them have broken. All of them have been boosted for 2-5 years on the stock motor, and none of these guys have ever been accused of babying their cars. They race and they race a lot. If your tune is there, the engine will stay there. Don't rev it past stock redline though is my advice. I think that's the main failure point for most VQ35s with boost these days. Dinky rod bolts, not dinky rods.
__________________
95 SE - Stock 3.0L w/ USIM - T61/P-trim @ 14.5psi - 93 octane
11.76 @ 121 - 1.82 60' - ET Street DOTs
12.15 @ 123 - 1.95 60' - Nitto DR
3.5L swap with I/Y/E
12.92 @ 104 - 1.69 60' - M&H Slicks
13.60 @ 103 - 2.15 60' - Street tires
96 GXE - I/Y/E/MEVI/JWT ECU
13.42 @ 102 - 1.87 60' - M&H Slicks
13.82 @ 102 - 2.17 60' - Street tires
95 GXE - Stock winter beater
14.28 @ 95 - 2.07 60' - Street tires
High Flow Fuel Injectors
Injector Cleaning & Servicing
www.DeatschWerks.com
Nealoc187 is offline   Reply With Quote
Old 10-14-2009, 04:19 AM   #8
Quote:
thanks, man,im taking everyones advise. just keep hearing bad things about the rods (no bolts) , even from nissan master tech's who know these engines. they have told me they lightend (weakend) the rods in order to get more rev from these engine. ??? i will have to do some research, i heard a lot of these go out after about 420 sh.. im still not buying the rod bolt story. rod bolts are an easy fix. any of those 470 whp daily abusers out by DC area? do they have 2 diff boost maps or they run 470 on pump gas?? sund like a 15-16 boost horsepower more or less, hard to believe on stock engine, reliably atleast,, but ill definitely research for sure
Old 10-14-2009, 04:51 AM   #9
just read up on the z forum, looks like the DE's are done safely at about 400-420 range, people have seen more and also have in time bent the rods, not blown the engines. BUT the HR engines can take well above 450 ....
also read some crazy *** dudes actually drop 20k on a non built turbo kit at shops making about 420, whp, and you can expect 30k for 600 whp built engine setups...godam, who would not drop that money on a freaking supra, or z06... dam crazy... but im sure thats people that get their oil changes and tune ups done at that local goodyear for madddd looot....
Old 10-14-2009, 12:21 PM   #10
I went with 96mm (stock is 95.5mm), but the only reason i went with bigger bore was to clean the walls, there were a couple scratches here and there.
Also for the main and rod bearings I went with standard, just had it micropolished. I also measured it myself with a Micrometer and it was exactly the same as the FSM specs showed. I used ACL standard vq35 sized bearings.
You wont have issues with standard size pistons, i havent heared of a single case that a piston has had issues even stock (except for bad tune, user error). I would listen to Neal, its def in the tune, which means your going to need to invest in some tuning equipment. J&S Safeguard (seriously recommend it) which you can retard timing with it, keeping your SAFC will work but i recommend a stronger device such as the EU.
and yea man them Z guys put down insane amounts of money for their builds. My engine build cost me 2600 at most, lets say 3k. They spend 15k for the same build lol, although most of the time they buy brand new blocks and heads, etc... that alone is a few thousand. $15k(just on the motor) for 450whp lmao that's laughable.
__________________
Old 10-14-2009, 01:22 PM   #11
ok, so in theory one can get away with droping stock sized forged pistons and rods, polish them up , balance the rotatiing assembly and the build should be relatively non expensive at the end of the day if everything measures up.
im not sure i will build something, i think id be happy back at the 390-400 whp which according to Neal and the Z site is about the max safe whp. so for now, ill start looking for good stuff cheap,
Old 10-14-2009, 02:14 PM   #12
Yea stock bore is fine. To give you an idea, pistons were $600(all bore's were same price), rods were $400, bearings $130. Then machine work and balacing like another 450, and thats basically it, just stock HR head gasket and bolts, and your set.
OR, put in a VQ30DEK and run 20psi on that ***** all day lol.
__________________
Old 10-14-2009, 02:26 PM   #13
SLOW
Nealoc187's Avatar
These guys are all in the chicago area, and all of them run (or ran) on pump gas. Whether you buy it or not, it's the truth. Briguymax, phunk, James, and McDerns are their names on my350z. all of them ran mid to high 11s @ 120+ on pump gas on their stock motors, none of them ever blew a motor. APS TT, Greddy TT, APS Single, and Greddy TT kits respectively, 10lbs boost for the twins and 12lbs for the APS single - all on pump gas. none of us bother with race gas. When I say "blew a motor" i mean had *any* problems. you bed a rod and have to replace it, that counts as blowing a motor in my book. how well it is tuned is the determining factor.
a HUGE majority of the guys that have blown motors recently have been revving past the stock redline. i've researched it extensively in addition to having firsthand knowledge of my 4 guys that I know, I'm banking the longevity of my motor on it. I'm convinced.
what a nissan master tech has to say about it is generally of very little value in these discussions, dealer techs usually don't know their arse from a hole in the ground when it comes to mods and pushing the limits, unless they are involved in modifying cars themselves, which most of them are not.
__________________
Old 10-14-2009, 03:24 PM   #14
btw off topic, Neal you were right about running stock timing with my setup at my boost. I got basically near stock timing with no knock and pulling hard.
__________________
Old 10-14-2009, 04:44 PM   #15
SLOW
Nealoc187's Avatar
Nice dude. your shiz has to scream now.
__________________
Old 10-14-2009, 05:25 PM   #16
Send a message via AIM to 95BLKMAX
Alvaro!!!! Are you trying to make you max keep up with your GN??? haha
__________________
Guys I need money to recover from my recent engine build (it wasnt by choice LOL). Im selling a Holset turbo if you are interested
95BLKMAX is offline   Reply With Quote
Old 10-14-2009, 09:40 PM   #17
maxgtr2000's Avatar
I hope that is the case. I hear of vq35s blowing left and right. I'm gonna keep an eye out as well. It would be nice to figure out since these motors can be beasts with boost.
Old 10-14-2009, 10:23 PM   #18
Hell yea it does, why you think Alvaro (aic96max) wants to boost his 3.5 lol. cuz i keep texting him about my ****
__________________
Old 10-15-2009, 04:33 AM   #19
KRRZ350's Avatar
Send a message via AIM to KRRZ350
10char
Quote:
Originally Posted by DandyMax View Post
Very interesting post from Intense Motorsports over on my350z today:
http://www.my350z.com/forum/showpost...&postcount=269
Excerpts:
Quote:
Our 906whp stock sleeve, stock head gaskets, stock crank, stock ignition, standard ARP head studs, VQ35de was the first VQ we EVER built. We did ZERO research in what other builders were, had, or are doing. An engine is an engine. We didn't need to know what others had done because 95% of the builders still haven't achieved what we have in engineering.
(I can qualify and quantify this statement by the fact that we've had our hands in Adam Saruwatari's low 7-second 3.2L V6 NSX motor for over 6 years now)
http://www.carandmodel.com/featuredcar/4.php
If we had, wouldn't you agree that we would have upgraded the head studs to L19 or better?
Wouldn't you agree that we would have upgraded the head gaskets to HKS, or an alternative?
Wouldn't you agree that we would have upgraded the ignition to HKS, or an alternative?
ProEFI, PowerLab, and Intense teamed together to find the limitations of the stock block. Instead of reading up on what everyone else had done, and what was considered "true", we wanted to find out ourselves. On a completely bone stock motor, we bent every single rod at 540ft/tq and 600whp (perfect tune!). At that time the motor was pulled and stock bore pistons and after market rods were put in -- no machining to the block was done whatsoever.
At this time the testing of the stock sleeves was in order. The first test was with the PowerLab GT35R. We maxed the turbo out at 650whp. The next test was with the GT37R. We maxed that turbo out at just over 700whp. The final test was the 76S, which maxed out our clutch at 906whp -- sleeves still perfect! Again, all of these TESTS were with the stock block, no machine work, stock sleeves, stock head gaskets, stock ignition, stock crank. As you can see, we wanted to not only keep everything as stock as possible to be as true of a test as possible, but also to keep it cheap -- as to show everyone that with off the shelf parts, efficient off the shelf turbo system (PowerLab GT35R), and off the shelf engine management (ProEFI 48), reliable, high horsepower can be obtained by anyone!
You are correct that we learned the majority of our engineering from building 2zj-gte motors over the years -- and that's where the majority of our "expendable $$$" ended. We've also built 1400whp Viper motors, 1000whp 20b motors, and many many others. The common threads that links all of these successful motor builds are 2 things:
1. Efficient turbo systems
2. Efficient engine management (AEM at that time -- the designer of which, Jason Siebels, who quit AEM to start his own company.. ProEFI)
We took this philosophy and applied it to our first VQ build -- which still holds the world record for stock sleeve, stock crank VQ at 906whp. The SAME motor is in the world's quickest/fastest G35 coupe (11.00 @ 128mph) at only 600whp!
__________________
Gatorade on my keyboard FTL.
5th & 5.5 gen VLSD Auto transmissions for sale, PM me.
Cheap VIAS block plates
Dual-mass 6-speed flywheel resurfacing available!
NX wet kit w/digital gauge $400 shipped
KRRZ350 is offline   Reply With Quote
Old 10-15-2009, 09:46 AM   #20
Wow iv never seen that post before, awesome find. Now I know how much my engine can hold with my Eagles and Wiseco's
Alvaro, so 600whp is your limit. In other words, no need for build for your goals
__________________
Old 10-16-2009, 05:17 PM   #21
Send a message via AIM to ghostmax301 Send a message via MSN to ghostmax301
for 600whp i think he still needs new oem rings and bearings and possibly HR headgaskets and bolts.
__________________
VQ30DE-13.98@98
VQ30DE-K-13.61@101
VQ35-13.55@103
(no tune,street tires)
DE-K. Walbro 255lph. Z32TT fuel filter. PFTB. Full exhaust. Fidanza Flywheel. 5spd swap. S/S full clutch & brake lines. I.D. Lip kit. 97-99 Int. & ext. conversion. 2k1 cluster. 2k3 seats
ghostmax301 is offline   Reply With Quote
Old 10-17-2009, 09:26 PM   #22
ill ignore the master techs comment, let just say these guys build nissans , and not stock.
so , can you provide some additional information as to what these cars are using for tuning? size of a sigle turbo? do these motors have turbos that load the engine gradually? etc...and besides timing control in order to not have knock and the afr, what else would you consider very important on the tune??? evbryone says the tune is very important??? what afr are they tuning the engines to?
i want to know the secret to this how well, bc if a car makes power, doesnt have ANY detonation, and has good afr, then, is it porperly tuned or not?
im sure guys that have blown engines were not all running there cars with audible pinging and saying "**** ii nothing will happen"
any addtional information as far as setup would be greatly appreciated.
I dont plan on extending my limiter, when you make power that is not needed. you pm me the additional info
Old 10-17-2009, 09:42 PM   #23
i want 400whp that i can push everyday of the week for the next 5 yrs, lol lol forget 600whp. yeah, looks like they did it with arp headstuds only. isnt there vid on youtube wher a z made a 300 hp shot pass, but eventually blew, not sure how reliable it would be at 600whp, eventually it would give, maybe not in a couple dyno pulls during testing?????, i want to talk to some people and get specific setup data and more info before embarking on this ..
Abdala, i want to see the 1/4 vid soon.. common man , do it
Old 10-22-2009, 12:37 PM   #24
The rule of thumb on the VQ is 10psi max. Go anymore than that and you shorten the life of the engine dramaticly. (stock block)
Another thing to think about is what ems you are running. A better ems (haltech plat, hks vpro, etc) will insure a better tune and increase longevity. I ran a UTEC on my Z when NA/nitrous and early boost. I hated it on boost. immediately ripped that **** out for a vpro...it was night and day. So you if you want your VQ to last, don't skimp on engine management. I'd run lower boost if I were running anything but a stand alone. My buddy ran his 350Z with a 100 shot for a year and then threw on twins @ 10psi (490whp) and drove it like that for a year before he ever built the motor. He was running the VPRO.
and filling the nitrous bottle may suck, but the added issues of boost being in the equation sucks alot harder than filling up the bottle. gas mileage gets worse on boost too. If you never plan on building the motor, I'd suggest 100 shot.
BuiltnBoostedZ is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
