Supercharged/TurbochargedThe increase in air/fuel pressure above atmospheric pressure in the intake system caused by the action of a supercharger or turbocharger attached to an engine.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
FPR (AEM) + Vortech FMU + DEK Injectors for 11lbs SCing ????
Alright, don't know much so thats why I ask.
I have AEM FPR (ill get the model) with a vortech FMU which I beleive is 6:1 ration with DEK injectors. The pully on my SC is 3.125" which I beleive gives ~11 pounds of boost. Can the FPR and FMU help push/regulate enough fuel for the DEK injectors?
How much CC can be pushed with such a setup?
I will purchase 440cc injectors and a walbro 255 fuel pump and just tune via EU but for know I have to work with what I have.
I guess the FPR should regulate a certain amount of PSI with the vortech @ 6:1.
Dejavu. Didn't we already go over this in your other thread? LOL
You can't cut corners. You gotta have the better fuel pump (ie Walbro) or else you'll be running lean. Should of bought the fuel pump (only like $85 BNIB) instead of the AFPR, since it appears you're on a tight budget. The AFPR will be useless once you get the bigger injectors too btw.
__________________
99 Max SE 5 spd, SC'd, MEVI, Cattman Headers, LED tails, R34's with S2000 projectors, 13.1" Brembo BBK, EU.....381 HP/323 TQ
The AFPR came with the kit I bought. I'll buy the walbro 255LHP (GSS342)
If im correct you only need the pump. Everything else can be reused?
Wizard doesnt he still need the AFPR when he goes with the bigger injectors? Lower fuel pressure to compensate for larger injectors at idle.
__________________
98 Nissan Maxima..
Mods..
Supercharged, FMIC, K&N CAI, 00VI, VAFCII, Short Ram intake, Budget Y, warpspeed high flow cat, Greddy SP2 Catback, dropped!!
Zeitronix wideband and datalogging laptop just for tuning
