Supercharged/TurbochargedThe increase in air/fuel pressure above atmospheric pressure in the intake system caused by the action of a supercharger or turbocharger attached to an engine.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
As long as you have the Emanage for tuning you would not need an FMU no matter what your boost pressure. However, I do not know if the stock injectors are adequate for the power you will be producing at 11psi. You could get away with it if you got some kind of rising rate fuel pressure regulator to bump up fuel pressure.
Dont forget Chris, im running 11psi on stock DE-K injectors ;D
__________________
'01 Merlot SE-SC
Vortech V2 11psi w/ PFTB, Exhaust headers + Megan OE-RS Catback, Apexi Neo, CF Hood, SE-R wheels slammed on D2's, and the list goes on..
'99 Silver SE-L
AE Headlights, AE Wheels, Smoked corner lights, Mini Luda lip, and everything else bone stock..
I bought a supercharger kit that's on it way and was wondering with 11 pounds of boost and no FMU will I be able to run it tuned via Emanage Ultimate?
I currently have the 00vi with DEK injectors which are 290cc if im correct.
YEs but you are maxing those things out. Do it right and get bigger ones. And you might want to thing of a 255lph HP fule pump. The stock will NOT make it past 6-7lbs. Believe me.
__________________
98 Nissan Maxima..
Mods..
Supercharged, FMIC, K&N CAI, 00VI, VAFCII, Short Ram intake, Budget Y, warpspeed high flow cat, Greddy SP2 Catback, dropped!!
Zeitronix wideband and datalogging laptop just for tuning
Get bigger injectors. and no question about it, you NEED a fuel pump, dont use the stock one. And if you cant get injectors for any reason at LEAST get an FMU.
That i know.. i've been lurking around for a set of good injectors for a decent price. But until then, my fmu setup will suffice without romping on the pedal too much.
To the OP, if youre going to use an FMU for the time being until you can get bigger injectors to elimate the fmu, get a 8:1 disk and you'll be set.
__________________
'01 Merlot SE-SC
'99 Silver SE-L
wow, your running an fmu right?
i ran 5-6 psi on dek injectors and was starting to max them out (9-10afr was 95 -100% DC at 5500rpm), i've added an fmu (6:1) and run 8.5psi now, not sure exactly what the DC of the injectors are now but afr is about 11
plus, the bigger the injectors, the richer the tune you can have, which means the more advanced the timing can be.. which is where you make all your power on a 3.0lt
Of course im running an FMU ahaha
__________________
'01 Merlot SE-SC
'99 Silver SE-L
Yeah but you dont want to run too rich.
And yes, when you begin advancing timing you can richen the tune up a bit to avoid detonation but without seeing your power outputs how do you know just where in the powerband to advance timing and by how much to yeild the best gains?
