Go Back   Maxima Forums > Advanced Performance > Supercharged/Turbocharged
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 09-19-2009, 04:43 PM   #1
does everyone upgrade to a 300zx maf?
i just upgraded my turbo and my innercooler setup and now when i floor it and i start seeing boost the cars boogs out like symptoms of a bad maf. im thinking im maxing out the stock maf . i was told that i can clamp the stock maf with the emanage boost cut feature but i cant get it to work. i have the greddy pressure sensor hooked up as well. does anyone still have their stock maf? or everyone just upgrades to the n62 300zx maf? my current setup t67 turbo with 555cc injectors and my old setup t04 50 trim turbo with stock injectors both at 8lbs of boost. any suggestions or anyone knows how to get the boost cut feature to work?
__________________
eat......sleep.......boost
chino86 is offline   Reply With Quote
Old 09-19-2009, 07:35 PM   #2
KH3 by popular demand
maxgtr2000's Avatar
Send a message via Yahoo to maxgtr2000
I'm on the stock maf with the pressure sensor. My car hasn't been professionally tuned so I'm not maxing mine out, the most I've seen was 4 volts. Since you are on a t67 with 555cc you might want to just go and get the z32. I'm only on 370cc with a t3/t4. If you can log on the wideband just see what rpm range you are leaning out and add injection (if you have the greddy injector harness). I clamped the maf once but it started bucking so I don't use it I just add and subtract as needed. You can also log the maf voltage and see where it maxes out also and fix your injection.
__________________
Retrofit headlight services
My VQ30DET
Emanage Blue and Ultimate Forums
There can be no peace until you possess the Prince of Peace.
maxgtr2000 is offline   Reply With Quote
Old 09-19-2009, 09:39 PM   #3
Send a message via AIM to streetzlegend Send a message via Yahoo to streetzlegend
Yea, although you CAN continue to use the stock maf, it will make life alot easier if you use a z32 maf. with my 3.0, i had the stock maf maxed out completely, boost was at 15psi. Short answer, yes, upgrade it. I havnt experienced with the boost cut feature, but i know you can completely remove the MAF with the EU.
__________________
Streetz goes into the 11's!!!
440CC RC injectors for sale, $220 Shipped. PM ME
streetzlegend is offline   Reply With Quote
Old 09-20-2009, 12:16 AM   #4
what kind of spark plugs do you have in your car? and if so did you gap them?
TurboA32 is offline   Reply With Quote
Old 09-20-2009, 02:14 PM   #5
Quote:
You have to gap them depending on the boost. You start reducing the gap once you get spark blowout. Iv always used NGK copper, 2step colder. bkr7es-11 for the 3.0, and for 3.5 havnt memorized it yet lol
__________________
Old 09-20-2009, 05:38 PM   #6
i have ngk platinum 1 step colder at stock gap. once i get my car running right then i will regap them
__________________
Old 09-28-2009, 09:45 AM   #7
The Original CF Maxima
Flava_24/7's Avatar
Quote:
You definately need to gap the plugs accordingly. If your maxing out the MAF you can bet the plugs being at stock gap are also going to be an issue.
__________________
Chumps try to imitate but can never duplicate
377hp 338tq
Flava_24/7 is offline   Reply With Quote
Old 09-29-2009, 11:00 AM   #8
Carbon Fiber addict
This could be the source of your stumbling. ie spark blowout. Regap now, not later. This could fix your issue and you might be able to get by w/o the Z32 MAF.
__________________
99 Max SE 5 spd, SC'd, MEVI, Cattman Headers, LED tails, R34's with S2000 projectors, 13.1" Brembo BBK, EU.....381 HP/323 TQ
The Wizard is offline   Reply With Quote
Old 09-29-2009, 12:07 PM   #9
Quote:
ngk 3.5 plugs one step colder LFR6A-11.
Old 09-29-2009, 12:14 PM   #10
and if i were you i would upgrade to the z32 maf anyway. why are you still useing the stock maf?
Old 09-30-2009, 01:49 PM   #11
so i finally got around to regapping my plugs turns out it was spark blowout n my maf maxing out. i gapped the plugs to .032 and took it for a test drive no more hesitation until about 5500 rpm thats where the maf was maxing out and boost was higher than before i'm guessing from the huge pressure drop from the extra intercooler piping. maf maxed out around 14psi, i got the boost cut feature to work dropped the voltage clamp to 4.1 volts and now its running like it should. now i have to worry about traction issues its not grippin for s**t.
__________________
Old 10-10-2009, 06:13 PM   #12
didnt follow up on this thread, glad you got the car running properly now. This is on a 3.5 right? We should meet at the track one day.
__________________
Old 11-03-2009, 11:46 AM   #13
Redlinemax Owner
Redmax's Avatar
Send a message via AIM to Redmax
You would also want to change your plugs to copper or iridium as well. If there is plug failure and the tip of the plug breaks off in your motor, the platinum will not burn up and pass through the motor where the copper or iridium will.
__________________
Redmax is offline   Reply With Quote
Old 11-03-2009, 12:53 PM   #14
I would recommend copper. its the softest out of all, so if for some reason you run into pretty bad detonation or preignition then the plug will most likely melt before more serious engine damage is done.
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
