Go Back   Maxima Forums > Advanced Performance > Supercharged/Turbocharged
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 09-04-2009, 11:13 AM   #1
Send a message via AIM to dfownz
Oil lines q's
Hey guys,
So I'm about to finally get my car inspected so I can bolt on my TURBO!!!!!! I only need the oil lines and I was wondering how you guys hooked them up.
I have an oil sandwich plate that will have a 1/8npt port for the feed line.
1 - I have a HX35, does anyone know what thread size the inlet/outlet are?
2 - Where do you guys hook up the drain?
3 - Ebay or no?
Any pics of how the drain install goes would be greatly appreciated!
Thanks in advance!
__________________
What will I end up doing with my Maxima?
dfownz is offline   Reply With Quote
Old 09-04-2009, 01:04 PM   #2
4.5 Gen & 3rd Gen
93altima's Avatar
in for some pics of some setups too but i was under the impression that it was best to use a brass T from the oil pressure unit that a sandwich plate because the oil filter location has too much oil pressure
__________________
1993 Maxima GXE 1995 Maxima GXE
As A De-K: 11/28/08 14.8 @ 93.8mph
As A 3.5: 03/13/09 14.1 @100mph
HPaddictionz
Team all out Nissan
93altima is offline   Reply With Quote
Old 09-04-2009, 02:35 PM   #3
I believe you need -4an feed and a -10an drain lines. I hear that you can go with a -3an for the feed and you do not need an oil restrictor if you do. The drain fitting is just your standard t3. The feed fitting is 12.5mm I believe. You can order a 12.5mm to-4an fitting from Summit. It is an Earl's fitting. Hope this helps.
nismomaxct is offline   Reply With Quote
Old 09-05-2009, 03:13 PM   #4
KH3 by popular demand
maxgtr2000's Avatar
Send a message via Yahoo to maxgtr2000
Tap the upper oil pan if possible. If not you can get away with tapping the lower one.
__________________
Retrofit headlight services
My VQ30DET
Emanage Blue and Ultimate Forums
There can be no peace until you possess the Prince of Peace.
maxgtr2000 is offline   Reply With Quote
Old 09-06-2009, 08:03 AM   #5
Is there any specific location you guys used for the upper? I'd rather do it right the first time.
__________________
Old 09-10-2009, 09:47 PM   #6
Send a message via AIM to s1mply_v
^ I want dyno numbers when your done! I finished my S/C setup.
__________________
'01 Merlot SE-SC
Vortech V2 11psi w/ PFTB, Exhaust headers + Megan OE-RS Catback, Apexi Neo, CF Hood, SE-R wheels slammed on D2's, and the list goes on..
'99 Silver SE-L
AE Headlights, AE Wheels, Smoked corner lights, Mini Luda lip, and everything else bone stock..
s1mply_v is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
