Supercharged/TurbochargedThe increase in air/fuel pressure above atmospheric pressure in the intake system caused by the action of a supercharger or turbocharger attached to an engine.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
These last few days has been hell for NYC'ers, and even more for me. Every time I go some where, within 5 minutes my car struggles to drive and starts bucking back and forth (depending more gas I give it and how hot it is outside) before eventually dieing. I start it back it up, it bucks and backfire some more and stays between 1k-2.5k rpm Before dieing all over again.......
Here's my setup
2000 Nissan Maxima SE
440cc injectors
Greddy EU
60-1 turbo @ 12psi
38mm wastegate
2.5 exhaust
5 speed with quaife LSD
And BTW
Thanks in Advance
__________________
Nissan lover with an TC Maxima and 700whp turbo S13..
it's an engine management problem obviously, whether it's caused a bad tune/part of a tune or a bad sensor is another question. what is your wideband showing AFR-wise when it does this? what maps are being used for tuning on your EU?
__________________ 95 SE - Stock 3.0L w/ USIM - T61/P-trim @ 14.5psi - 93 octane
11.76 @ 121 - 1.82 60' - ET Street DOTs
12.15 @ 123 - 1.95 60' - Nitto DR 3.5L swap with I/Y/E
12.92 @ 104 - 1.69 60' - M&H Slicks
13.60 @ 103 - 2.15 60' - Street tires
Its def an electrical/engine management problem, id start with going over the maps you currently are using, and also check out the wideband when car is acting up. other than that, id look at MAF, and TPS, both of those will cause such conditions.
Well I have a AEM wideband but the 02 sensors needs to be replace. Before it went dead it was reading 14.6-15.1 idle. Also my MAF is bad too.....(soon to install my brand new Z32 maf this week). And the maps part I dont know because I'm not the one tuning, but I'll ask....
__________________
I know, electrical problems sucks.... But I'll get it make fix soon
__________________
To be honest I would troublshoot the car as if it were N/A first.
I have a n/a max with bolt-ons as my DD & I had very similar symptoms...
(Long story short) Turned out to be a bad tank of gas & a dirty fuel filter.
Good luck.
